Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 12-01-2011, 01:55 PM
zacmorton zacmorton is offline
ls, intermittent heat, and fan radiator fan running more than normal
01 lincoln ls, v6, intermittent heat, and once the car warms up the fan runs way more than it ever has, sounds like I'm stuck in traffic in the middle of summer.
when the car is idling the fans slows down, as soon as the RPM's increase the fan seems to ramp up as well.
Thanks
Old 12-01-2011, 09:07 PM
joegr joegr is offline
Re: ls, intermittent heat, and fan radiator fan running more than normal
You probably have a cooling system leak somewhere that is allowing air into the system. The degas bottle is almost certainly cracked and needs to be replaced, but you may have other leaks too.
94 thunderbird radiator fan/ temp gauge problem frustrated by now Thunderbird 19 08-09-2009 11:05 AM
Running cooler than normal 94HeavyChevy Caprice 4 01-27-2008 06:16 PM
1972 blazer running louder than normal blzrman Problem Diagnosis 4 06-14-2007 12:42 PM
1972 blazer running louder than normal blzrman 1969 - 1994 Full size 0 06-13-2007 10:19 AM
Engine Viberating more than normal 1992eclipseGS Eclipse Problem Diagnosis 4 04-08-2006 03:20 PM
