Go Back   Automotive Forums Car Chat > Honda > General Discussion
Old 11-30-2011, 09:31 PM
Sizzlinninja Sizzlinninja is offline
Cleaning idle air-control valve?
In quote I was told to "Your problem is that you have a DIRTY idle air control valve which can easily be broght back to life with a can of GUM-OUT spray. Best to run SeaFoam or AMSOIL FOAMING CLEANER through this, and your PCV valve and hoses"... Okay first of all, do modern day cars even have idle aircontrol valves? Or just cars with carburetors? I was told by someone I needed to clean my idle air-control valve on my 2002 Honda Civic, (it has a 2005 VTEC in it). If my car even has an "idle air control valve", how would I locate it, how would I clean it, and what would I use to clean it? Also, what is it that I am suppose to do with that SeaFoam stuff? Please help me if you can!
Old 12-01-2011, 11:13 AM
somick's Avatar
somick somick is offline
Re: Cleaning idle air-control valve?
Search You Tube for "Eric the car guy". He has a video on this topic.
There is also a thread in Accord section. If I find it I will post it here.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 12-01-2011, 11:20 AM
somick's Avatar
I cannot answer your question about 2002 Accord, but if you have IAC valve there, here is a thread on how to clean it:
http://www.automotiveforums.com/vbul....php?t=1069569
I hope this helps,
Sam
ICV Idle Control Valve not working squawcrk Cavalier Problem Diagnosis 1 07-03-2010 01:04 PM
2002 V6 cleaning the Idle Air Control Valve Fluvannahoo Rodeo | Passport | MU 3 11-20-2006 02:07 PM
Idle air control valve, bad idle bigjerr Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 10-26-2006 01:22 AM
Idle air control valve cleaning procedure vwjetta96 Jetta/Vento/Bora 0 06-04-2005 11:15 PM
