Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 11-28-2011, 07:53 PM
berndawg berndawg is offline
2001 SL won't start irradic
The car will not start 10 times in a row and then start for weeks. No rhyme or reason. No temp problems etc. HOWEVER the clutch does NOT have to be pushed in to start it. I am thinking the clutch interlock was a requirement and perhaps that is causing the problem.
Anyone have a thought?
Old 11-29-2011, 02:29 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2001 SL won't start irradic
What do you mean "won't start". Is it a crank, no start or will it not crank over at all?
Old 11-29-2011, 03:02 PM
Everything electrical works but it won't turn over. Fuel is fine batter is fine. If Push and pop the clutch it starts.
It will be just fine the not start. Then it could not start several times in a row OR just once.
Old 11-29-2011, 06:30 PM
gmtech1's Avatar
Sounds like a problem with the clutch switch. Check the connector at the switch, check the switch itself with a meter when it's pushed in and released.
Old 11-29-2011, 10:54 PM
Ruley73's Avatar
Ruley73 Ruley73 is offline
In your case the clutch switch may be bad, but that doesn't appear to be what is preventing the car from starting. I think you either have a bad connection at the battery or a bad starter. These cars are very sensitive to bad connections at the battery terminals.
If you look, you will see that the size of the positive wire going to the starter is much thicker than the positive cable going to the fuse box under the hood. This is because the starter alone requires substantially more power than the rest of the car's combined electrical load. The bad connection at the battery may be sufficient for everything else, but not for the current required for the starter.
There is no 100% accurate way to check for a bad starter. It could have a bad spot in it. I had a starter like this. I had to push start it a handful of times in the 4 years I owned it. Then suddenly the starter would not work at all.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
Old 11-30-2011, 10:33 PM
A paper clip had been inserted in the plug to the clutch interlock. THAT is why it could be started without the clutch being depressed. I bought an new switch and installed it and THAT was not the problem. NEXT I'll trace down that big wire from the battery.
ls 2001 won't start after battery changed tjach LS | MKZ 6 04-27-2010 06:07 PM
Kia Rio 2001 won't start! neiji Rio | Rio Cinco | Pride 0 12-29-2006 04:06 PM
2001 Won't Start - Regulator Change? hcary Problem Diagnosis 6 12-01-2006 10:30 AM
2001 won't start... BadAzzGrandAm Grand AM 6 07-06-2005 05:02 PM
