Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 11-25-2011, 01:57 AM
stevo2412 stevo2412 is offline
eclipse power problems. ~help~
this is weird i just bought this car it had to many problems im all good now except one.. for some reason when im at idle and i turn my air or heat on my lights dim down and my idle drops and sometimes my car almost shuts off. i dont know why it does this but i need some help. any ideas? before i buy a new battery.
thanks
Old 11-27-2011, 04:29 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: eclipse power problems. ~help~
Sounds like the alternator. Whenever you engage accessories that draw more power, lights may dim slightly. I have seen that with several of my cars. If it is drawing so much that the alternator is unable to supply enough power to even keep the motor running then I would have it tested to make sure it's producing enough power. I do believe any Autozone or similar store can test the alternator for you, although I don't know if they can do it on the car or not.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 12-10-2011, 03:53 PM
i dont know if its the alternator but iv attempted to check for vacuum leaks and i have unplugged my air compressor since this only happens when i turn my a/c on or defrost. i really have no idea what it could be but i need help im getting frustrated!
Old 12-12-2011, 07:50 AM
You need to check the alternator...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 12-13-2011, 11:46 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Definitely have the alternator checked out. Also may want to check the IAC, if the motor is dropping the idle with the accessories on. It should be compensating for the increased load.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
loss of power impala03ryder Impala | Impala SS 2 10-10-2010 10:24 PM
96 Eclipse Rs Non-turbo Vacuum problem. donidavis Eclipse Problem Diagnosis 27 08-29-2010 09:07 PM
Please Help, '99 AT Mitsu Eclipse won't shift into 3rd '99EclipseProblems Engine, Transmission and Drivetrain 6 09-13-2009 10:03 PM
95 eclipse gs blue smoke won't start hcruz32 Eclipse Problem Diagnosis 1 03-20-2009 09:36 PM
eclipse gsx problems???? TMUMMY Off-Topic 7 01-04-2004 02:32 AM
