Old 11-22-2011, 05:54 PM
killermrob83 killermrob83 is offline
Over-head reading lights
'07 Grand Caravan SXT. The bulb (I believe) has gone out in the driver side over-head reading light, the one on the left hand side of the over-head console. How does one go about getting to the bulb to replace it. There is one screw that I have been able to find, located at the rear of the console, which can be seen when the sunglass compartment is lowered. I removed the screw, but the console still seems to be attached to the roof somewhere in the middle of the console. I thought by removing the screw the console might slide rearward, allowing it to be removed from its cavity in the headliner, but such is not the case. I tried to slightly pry (being exceptionally careful so as not to break the plastic nipple that the lens roatates on) between the lens and console frame, but not sure there will be enough clearance to remove the lens as there are some tabs on the rear end of the lens that keep it from coming out of the console. Any ideas? Thank you for your time and consideration.
Old 12-02-2011, 11:59 AM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: Over-head reading lights
i did it per this site http://www.paulstravelpictures.com/D...ide/index.html
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
The Following User Says Thank You to chevyn0va1 For This Useful Post:
bignoisey (12-07-2011)
Old 12-02-2011, 12:59 PM
Thank you so much for the bulb replacement procedure link. One would think (but obviously not from the manufacturer's standpoint) that a replacement bulb would be made available from the dealership that would fit in place without having to modify it. Thanks again, chevyn0va1.
Old 12-02-2011, 01:41 PM
chevyn0va1's Avatar
no problem I had to look for the same thing when i bought my van a year ago. to be honest I didnt have to modify mine all that much. Napa might be a good place to get them too. But I might have found mine at walmart.
Old 12-02-2011, 04:01 PM
I will definitely be shopping around for the best fit/price. $5 for a little bulb seems kind of pricey, but the individual did mention that they had gotten it at the dealership.
Old 12-07-2011, 10:29 AM
bignoisey bignoisey is offline
I had the same problem with my '07 Caravan, but both map lights were not working. The procedure was valuable since I was trying to not break anything while getting to the bulbs. On mine both bulbs were still good, but some of the plastic holder was warped due to heat from the bulbs. A little scraping with a knife restored the electrical connections. Lets hear it for plastic car parts?
Old 12-07-2011, 12:20 PM
I have not as of yet removed the lens, so am not sure what the problem is. The high temps are only in the 30s and I am afraid that I will break something. Haven't had the time to go out with a hair dryer and warm things up, but will post some results once I do. Thank you for your responses.
Old 12-10-2011, 03:37 PM
Along the edge of the clear plastic lens there is a small notch. This is the pry point using a medium sized flat blade screwdriver. You might use a small piece of electrical tape to keep the metal blade from scratching the surrounding trim. I doubt that cold weather will cause the lens to crack.
Old 12-10-2011, 04:09 PM
Just to be on the safe side, I used a hair dryer to heat things up. Once I had the lens removed, it was obvious that the heating step was not necessary. With the lens in place, all that I could see was a plastic nipple protruding from the console. I figured that the lens had to clear the nipple in order to be removed, as if the lens had a hole in it that the nipple went through. The lens has a what I would call a c-clip (on both sides) that attaches it to the nipple that sticks out from the console.
I discovered that the bulb was not burned out. It seems as though there is not enough clearance/ventilation to allow the heat generated by the bulb to dissipate. The base of the bulb was discolored due to overheating (I noticed the same thing from one of the photos in the linked procedure). One of the electrical contact tabs was actually embedded and melted into the plastic of the base, not allowing it to come into contact with the power supply/ground connection (didn't investigate it that far), so no light. I was able to pry the contact up from the plastic quite easily, clean it up with some fine sand paper, and it worked fine upon reinstallation. Not exactly sure what the proper fix would be regarding the removal of more heat that is generated by the bulb. Looks like one could open up the upper end of the reflector a bit, as it already has somewhat of an opening (kind of a cross pattern). Seems to me that this is a design flaw; the bulb's power draw is excessive for the area that it is enclosed in. Anyone else have any proven methods of removing the excessive heat from around the bulb? Thanks so much for all of the info already given; I am very appreciative regarding such.
head and brake lights steve621 Dakota 12 06-30-2011 10:54 PM
1996 over head light cratercmc 1st Gen 95-99 5 04-23-2010 02:27 PM
ls block with a b20 head! read!!! mrlucci4051 JDM Motor & Parts info/chat 6 03-09-2004 12:27 PM
Clear Coat over Head/Tail Lights ShOrtyOC714 Car Modeling 3 12-04-2003 12:31 AM
tech heads - read this please ;) another j.fuggi dilemma j.fuggi Engineering/ Technical 4 03-08-2002 01:30 AM
