Old 11-22-2011, 04:18 PM
budguy007 budguy007 is offline
01 intrigue dash,gas gauge issues
I just bought a 01 Intrigue that the dash lights don't work and the gas gauge stays at fuel when you start the car. It goes to empty when you shut it off.
Old 11-22-2011, 08:35 PM
sparcx sparcx is offline
Re: 01 intrigue dash,gas gauge issues
gas gauge might be fuel sending unit. Give these two links a shot and see if it matches up with your symptoms:
http://www.automotiveforums.com/vbul...d.php?t=926087
http://oldsmobileforums.com/forums/s...ad.php?t=13447
not sure on the other dash lights issue. Maybe someone else has an idea.
The Following User Says Thank You to sparcx For This Useful Post:
budguy007 (02-07-2012)
Old 11-22-2011, 09:32 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
The gas gauge symptoms ( always full when switch is on and empty when switch is off ) indicate a break in the circuit feeding the gauge . Could be a wiring issue or something to do with the sender .
" Sometimes I grow so tired "
Old 11-26-2011, 10:30 PM
Thanks for the help I figured the dash lights out all five bulbs were blown. Going to try to replace part in fuel sending unit. I hope that fixes it. I dont have any reading on the odometer but it Im not worried about that unless someone has a easy fix.
Old 02-07-2012, 10:20 PM
Thanks for the help I actually got a deal on a new sending unit and pump. Replaced them both and now the gauge works fine. I had no idea where to even start to look without some help.
Gas Gauge Issue on Suburban jep5555 Suburban 4 11-13-2008 07:35 PM
Digital Dash gas gauge not reading correctly John T. Regal 8 01-14-2005 01:25 PM
Gas Gauge Issues Stormy62485 Contour 2 07-31-2004 07:40 PM
ABS light and gas gauge issues on my 98 Rodeo mrsmarilyn Rodeo | Passport | MU 2 05-05-2004 05:09 PM
Gas gauge issue? philbee Ranger | Courier 4 02-10-2004 10:02 PM
