Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 11-22-2011, 01:44 PM
mxz600 mxz600 is offline
95 ram won't start
95 ram, 3/4 ton, 4x4, 5.9 gas -
I have searched all over and can't figure out what to do next. Here is what has happened so far.
Within the last year, plugs/cap/rotor/wires/coil were replaced.
Truck ran one day, wouldn't crank the next. (put a new starter on, good to go).
Next day it fired right up and then died a couple minutes later. Would not refire without
the use of starting fluid.
Next day, got a fuel pressure tool and read 30PSI when key on and fuel pump ran. After
fuel pump shut off, pressure dropped right to zero (must be a bad fuel pump).
Ordered a new fuel pump and installed. Truck fired right up and then died within
30 seconds. Would not refire even on starting fluid.
Cranks and cranks and cranks so it's not the battery(even tried a new one) and it's not
the battery connections (clean and tight).
I scoured the internet for a crank position sensor location, but this thing doesn't have
one where they say they should be.
What to do next?
Thanks,
Jay
Old 11-22-2011, 06:49 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 95 ram won't start
Check this,
http://www.justanswer.com/dodge/4cll...r-located.html
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 11-23-2011, 05:12 PM
Local repair shop says pickup coil is bad and will have it done Friday for me.
There goes another buck forty.
Jay
Old 11-23-2011, 09:03 PM
AF - Advisor
Thanks for the update.
Sometimes I have to let a Pro look at my stuff too.
Old 11-24-2011, 08:37 PM
Yeah Chris, I give in when it's over my head and I hate looking up stuff and not seeing replies of what fixed it. Just glad to get the old girl back before the snow flies.
Jay
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 04:20 PM
95 dodge ram won't start jpacopley Ram Pickup | Ram SRT10 7 02-01-2005 11:42 PM
96 Ram won't start jr6768 Ram Pickup | Ram SRT10 3 01-27-2005 12:30 PM
1999 Ram won't start lakergrad Ram Pickup | Ram SRT10 12 11-10-2004 02:15 AM
2000 Dodge Ram Won't Start corjliza Ram Pickup | Ram SRT10 2 11-09-2004 09:58 AM
