Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 11-21-2011, 10:53 AM
will1976 will1976 is offline
1992 Deville No Heat
Hello, Just wanted some opinions on my heat problem. So far I have flushed the heatercore both ways(reattached hoses properly), flushed coolant system, changed thermostat(in its right direction), refilled radiator and reservoir to proper level. I have functioning brake release, and dont hear a vacuum leak. I had heat last winter. I guess it is the heatercore, but both hoses seem hot(the bottom one seems hotter). There is also no leak from the heatercore, and only one code E91. Thanks guys.
Old 11-21-2011, 12:15 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 1992 Deville No Heat
E91 is a PRNDL switch problem, probably not related to your heat problem. Sounds like you may have a problem with the temperature door or the controls for it.
Old 11-21-2011, 12:47 PM
sorry I left out that I have the dash apart, and see the door move when I change the heat settings.
Old 02-17-2012, 10:09 AM
was the heatercore
1992 DeVille will not start Southpaul Deville 2 10-09-2006 08:09 PM
1992 deville question Marsal420 Deville 2 06-30-2006 12:59 AM
1992 Devile Marsal420 Deville 3 06-23-2006 04:40 PM
1992 Deville Blower won't shut off joeplan1 Deville 2 11-12-2005 12:09 AM
1992 Deville won't start MikeReck Deville 4 10-16-2005 09:00 PM
