Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 11-20-2011, 08:13 AM
1hillbilly 1hillbilly is offline
van won't start when cold
1997 chevy express g 2500 4.3 vortec.the colder it is the harder to start.engine light on po 118 -high coolant temp circ high input,were is this sensor located,po-140 02 sensor ckt no acttivity [bank1 sensor2] [iat sensor/ckt intermittent]were are these sensors located.fuel pressure ok 65 lb on startup . runs good when started, no misses runs smooth, also coolent temp on gauge only rises just above 45 celcus no were near 100 celcus [thermostat will be replaced ] can you recomend best brand t stat ac delco last time used first two were defective out of box .and are there different temp ratings like back in the day.i live in canada the hotter the better.-20 celcus here yesterday did get van started- ing on till fuel pump started and stoped cranked 10-20 sec off, repeat 15 to 20 times finaly started fireing started, ran 1min stalled started finaly ran on high idol 1min normal idol no problem after that ran good. thank you in advance for taking the time to anser back its appreceated.i love this site keeps me on the road. on a low budget [aka to cheep to pay da man]thanks
Old 11-20-2011, 09:28 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: van won't start when cold
For code P0118 the coolant sensor to VCM/PCM is on front of engine.
Coolant sensor for dash gage is usuall in the middle side of cylinder head.
MT
The Following User Says Thank You to MT-2500 For This Useful Post:
1hillbilly (11-20-2011)
Old 11-20-2011, 02:59 PM
thanks mt must the sensor in side of t stat housing.hopfully this is cause of hard start will change t stat and sensor and post back.tnx
Old 11-20-2011, 07:21 PM
MT-2500's Avatar
AF - Advisor
Also check out the wiring plugin to it.
You are welcome and good luck.
MT
88 LeSabre won't start when cold fribergb LeSabre 37 01-25-2006 06:13 AM
1988 Dodge Power Ram LE150 won't start when cold or dies soon thereafter garcigar General Discussion 6 09-22-2004 07:49 PM
1988 Dodge Power Ram LE150 won't start when cold or dies soon thereafter garcigar Ram Pickup | Ram SRT10 0 09-18-2004 12:48 PM
65 Skylark won't start when cold knmhobbies Skylark 2 07-08-2004 02:43 AM
2000 Silverado won't start when cold Mel Tucker C/K 1 04-02-2004 05:39 AM
