Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 11-19-2011, 05:35 PM
JohnT396 JohnT396 is offline
2000 Sebring 2.4L Radiator Drain Petcock Replacement
I flushed the radiator and now, when I close the drain petcock, it leaks. Can the petcock be changed with the radiator still in the car or is this gong to turn into another 3 day project? Any idea what the process is to change one of these things?
Old 11-20-2011, 08:13 PM
Re: 2000 Sebring 2.4L Radiator Drain Petcock Replacement
The drain plug came out but with great difficulty. You need to turn the plug 90 degrees and then pull straight out. Don't pry it out. There is a small shoulder around the outside of the plug. I broke mine but thankfully there is no leak. When replacing the plug, lube it up, I used some silicone, pushed in and turned. All is good. Thanks,,
Radiator Coolant Drain - 2000 S10 Pick-up PaulVT Problem Diagnosis 1 01-03-2011 05:20 PM
2001 Durango 4.7L radiator drain plug mcknt Durango 0 09-26-2009 12:52 AM
Removal of 97 Radiator Drain Petcock? tigerbalm2424 Jimmy 3 05-22-2007 02:28 PM
Radiator Drain Petcock??? Troop2fish Trooper | SLX | Bighorn | Wizard 1 06-06-2005 04:24 PM
1999 Yukon radiator drain petcock location hcwarnerjr Yukon 2 05-17-2005 11:49 AM
