Old 01-02-2011, 03:16 PM
PaulVT PaulVT is offline
Radiator Coolant Drain - 2000 S10 Pick-up
I've reviewed posts related to my problem draining coolant from my S10, 2.2L (4 cyl.) The drain petcock on my vehicle is located on the driver side and is barely visible. On my truck the part is plastic and when viewed from the top tooks like a large tamper-resist screw head; the type that allows a screwdriver to turn only one way. One post I read correctly indentified that a 1/4" square socket will fit the petcock (drain) fitting. The 1/4" square drive fits at the center to open/close the fitting.
Unfortunately, in my case turning the petcock a quarter-turn did not drain the fluid (clogged?). I resorted to removing the lower radiator hose. Just as well - while it's loose I'll go ahead and replace the hose.
I hope this saves some searching. Good luck!
Old 01-03-2011, 05:20 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Re: Radiator Coolant Drain - 2000 S10 Pick-up
After the 1/4 turn, did you try pulling the plug out?
It slides about 1"
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
87 2WD Pick Up - Two Decades of Starting Problems MSW78 Older Pickups 5 11-21-2009 09:45 AM
s10 pick up h77mack S-10 1 04-27-2006 06:42 AM
where is the radiator coolant drain plug located on my '99? psanche Windstar 8 08-06-2005 08:54 PM
2000 Chevy Pick-up bartman75 C/K 1 06-14-2004 02:57 PM
Are differentials from 99 Tahoe and 2000 Chevrolet Pick-up interchangeable? Pocbills C/K 0 05-15-2004 08:16 PM
Tags
anti-freeze , coolant , drain , petcock , radiator
