Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 11-19-2011, 05:35 PM
mark_gober mark_gober is offline
07 Yukon ABS sensor resistance value
Hey everyone,
I recently posted here http://www.automotiveforums.com/vbul....php?t=1070044 about a stabilitrak issue my sisters Yukon was having.
She drove out here today and I took a look at her ABS sensors. The passengers side front sensor read an open with my multimeter and the drivers side read about 5.4Mohms. I suspect the passenger side is the faulty one, but the drivers side seems significantly higher than what I've seen quoted on other websites.
Does anyone have know the value these should read?
Mark
Old 11-19-2011, 05:58 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 07 Yukon ABS sensor resistance value
Without a known good sensor, it's hard to say for sure. Typically they are in the 1.3k-1.8k range. Do you know what codes are set? For sure the one that is open is bad.
Old 11-19-2011, 07:00 PM
maxwedge maxwedge is offline
A990 racer
Lightbulb Re: 07 Yukon ABS sensor resistance value
On average most GM sensors are about 1100-1200 ohms, but as mentioned you know the open circuit one is bad, replace that one and check the resistance first, then you have a std. to work with.
2001 Yukon O2 Sensor Problems belbers1 Yukon 10 02-10-2010 10:23 AM
ABS Wheel Sensor Resistance '97 Lesabre Smith1000 LeSabre 4 09-05-2007 08:19 AM
Fuel Level Sensor resistance drjimmy Grand Prix 2 08-30-2006 09:03 AM
Map Sensor Resistance Values swb1 Suburban 1 07-31-2006 03:46 PM
92 SE throttle position sensor resistance range mperez Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 06-14-2004 08:00 AM
