Old 11-18-2011, 01:16 PM
GTPFlorida GTPFlorida is offline
PLEASE HELP!! 1999 GTP Start up problem!!
Good day to all!!! I am currently working out a start up issue with my 1999 Pontiac Grand Prix GTP. The issue began about a week ago and I can't wrap my head around what it could be.
The car turns over just fine and I can rev it once before it dies. If the car sits for a long period of time (~12 hours or more) it will start just fine, idle erratically between 500 and 1700 RPM's for about a minute then finally level out at ~1000 RPM's. If I then turn the car off and back on it will not start again. I started to think it was an issue in the fuel system so I have since replaced the fuel filter, fuel pump and fuel pressure regulator. The issue still exists and is driving me crazy!!
Also, I am NOT getting any kind of check engine light so I can't diagnose this with error codes. Anybody have any ideas or experienced this issue before?? Please keep in mind that I am not a professional mechanic. Thanks in advance for any assistance provided!!
Old 11-18-2011, 06:42 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: PLEASE HELP!! 1999 GTP Start up problem!!
Welcome to AF!!
There are several possible causes. First, remove and clean the Idle Air Control motor on the side of the throttle body and clean it with throttle body cleaner. Just don't move the pintle when you have it off the car. Second, unplug the mass airflow sensor at the throttle body and start the car. If the issue goes away then the MAF is bad and needs to be replaced. They are expensive and don't purchase Cardone re-manufactured units because they are often bad.
I hope this helps.
Old 11-18-2011, 06:54 PM
Thank you so much for the reply/assist! I'll try both of these over the weekend and reply back with the results! Fingers crossed!!
Old 11-19-2011, 07:53 AM
GTP Dad- First, let me say thanks again for the assist! I unplugged the MAF sensor this morning and the car fired right up and had no issues idling! Upon reconnecting the sensor the engine would sputter and almost die again. I'll be replacing the sensor as soon as the part gets in!! Thanks again!!!
Old 11-19-2011, 07:54 PM
Tech II Tech II is offline
Just to backup what GTP Dad said, beware of aftermarket remans.....I had to replace one 3x's before I got one to work....and then it only lasted two days.....
1999 Chevy Malibu starts up, dies, then starts fine aem1988 Malibu 3 06-10-2011 03:06 PM
GTP Question Please Help bbaker1985 Grand Prix 6 03-27-2009 04:16 PM
99 GTP starts and then stalls buckeyeguy Grand Prix 2 03-16-2009 07:38 AM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
please help 1999 chevy cav wont start ofdisme Cavalier Problem Diagnosis 3 06-04-2008 02:10 PM
