Old 06-03-2008, 03:28 PM
ofdisme ofdisme is offline
please help 1999 chevy cav wont start
1999 chevy cav was running fine then girlfriend was driving stalled out! checked have good spark. with keys in ignition turned to on position can hear fuel pump turn on. and still cant start! work for fire dept in florida and have to work alot latley not much time please respond
Old 06-03-2008, 03:54 PM
inafogg inafogg is offline
Re: please help 1999 chevy cav wont start
Hello ofdisme,next step would be checking fuel pressure.if u dont have axcess to one u could try priming or spray carb cleaner in to see if it tries to start then.Good Luck
Old 06-03-2008, 05:24 PM
Helmuth48's Avatar
Helmuth48 Helmuth48 is offline
Talking Re: please help 1999 chevy cav wont start
1st....get rid of girl friend...that is a bad sign. Go to church on Sunday and ask for the curse to be removed !!!
2nd.... did you get a CEL ????
3rd... see if it will start with a little Starter/Ether sprayed in the air clean...may need to take the air cleaner top off.
Clogged Fuel Filter ?? Crank trigger...could be intermittent. ???
Cheer Mate... Jzjzz ..... Donk went to get somemore suds.
Old 06-04-2008, 02:10 PM
yhandor's Avatar
yhandor yhandor is offline
Send a message via MSN to yhandor
Listen to Hall and Oates, that will fix your cavalier
