Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 11-17-2011, 08:02 PM
bnerbas9 bnerbas9 is offline
2000 venture intermittent blower
Recently, the HVAC blower has become intermittent. Sometimes it will start right away when I start the engine, other times Have todrive a few klicks before it will kick in. Usually a good bump in the road or something like that will start it up. Everyone else is driving arond them, I'm aiming straight at them. Fuses OK, I've re-seated them, possibly a connector problem. Anyone out there had this happen or have some suggestions?
Also, found one answer to this: had locks repeatedly locking over and over, and also triggering the interior lights on, more so when the brakes were applied, to the point of draining the battery overnight. Turns out the installer for the remote start did a poor job under the drivers side carpet, and a broken wire was touching another exposed wire. It's not always the poor quality of the vehicle!
Anyone with a suggestion on the problem posed? Getting cold out (Canada) - hoping to find the solution soon,
Thanks,
Brad
Old 11-19-2011, 01:09 PM
Re: 2000 venture intermittent blower
Looks like I may have found the answer. I reached into the blower compartment, and cleaned out a couple of leaves and twigs - in winter I tend to not use the cabin filters for better air velocity and these fell in at some time. That by itself did not fix the problem. But what I found is that all I had to do was give the squirrel cage blower a little spin and away it goes. Anyone else seen this? Would that require new bearings? Any thoughts? A little awkward to give it a spin every time it doesn't start up by itself (75% of the time), but doable.
Old 11-19-2011, 05:53 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Sounds like the brushes are worn in the motor, I would replace the motor.
Old 11-19-2011, 06:04 PM
brcidd's Avatar
brcidd brcidd is offline
Pretty obvious- your blower motor is worn out- replace it--- kicking it to start it is my test to prove one is worn out..
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 11-20-2011, 10:31 PM
Thanks for the direction. My next step is to change it out.
The blower is slowing down & speeding up (sometimes can barely feel the air moving) and there are some noises coming from it. I was going to check a little closer into electrical, but will pursue the blower replacement first.
Thanks again!
Brad
2000 Venture blower fan high does not work stu padas Venture 1 09-18-2009 10:12 AM
2000 Venture Intermittent High Idle Speed EAGLESFAN Venture 12 07-09-2007 02:15 AM
00 venture rear blower does not work scattmann Venture 1 06-05-2007 05:00 PM
2000 Montana Blower Blower Motor PROV1 Montana/Montana SV6 5 06-23-2006 11:49 AM
2000 Venture Intermittent Starting Problem authenticy Venture 11 04-19-2005 01:44 PM
