Go Back   Automotive Forums .com Car Chat > Pontiac > Montana/Montana SV6
Old 06-21-2006, 01:16 AM   #1
PROV1
2000 Montana Blower Motor
My AC/Heater blower has never worked on the 1 or 2 settings. As of last week it's now only working on the number 4 setting. I replaced the switch, no luck, still only number 4. What's next? Could the blower motor resistor be the problem? Thanks for any advice.
PROV1 is offline   Reply With Quote
Old 06-21-2006, 05:12 AM   #2
Lucky-Luc
Re: 2000 Montana Blower Blower Motor
i change the resistor module on mine,,,,it is located at the passenger foot on the air duct,,,,
that fix the problem
Lucky-Luc
Lucky-Luc is offline   Reply With Quote
Old 06-21-2006, 08:23 AM   #3
hufhouse
hufhouse's Avatar
That's definitely the problem.
Get the new resistor at the dealership. It's located on the passenger side on the firewall behind the glove compartment. I removed the glove compartment for easier access. This is a pretty simple fix.
Unplug the old one.
Remove the old one (a couple screws, I think).
Install the new one.
Plug it in.
I don't think it's necessary to remove the glove compartment, but you don't have to be a contortionist to get to the part if you do.
hufhouse is offline   Reply With Quote
Old 06-21-2006, 09:00 AM   #4
rubberman
i have a 99 with the same issue but fan speeds 1 and 2 dont work but 3 and up do. its been like that for a couple yrs but havent cared enough to change it out since the other 3 speeds works fine. what is the part number for the blower resistor?
2000 Grand Prix GT w/ gold package.
K&N CAI intake, U bend delete, ZZP PCM, Ractive oval exhaust tips, ZZP 3" downpipe
2004 Chevy Trailblazer EXT
Keep on Keeping on...
rubberman is offline   Reply With Quote
Old 06-21-2006, 12:35 PM   #5
hufhouse
hufhouse's Avatar
I'm sure the Pontiac dealer will know the part. It's a very common repair.
Generally, these get progressively worse. First, fan position one stops, then 2, then 3, etc.
It's probably most annoying in slightly hot weather, when you can't turn down the AC and you can hang beef in the van.
Old 06-23-2006, 12:49 PM   #6
PROV1
Thanks for the help. I replaced the resistor module and all is well. I actually ended up removing the fan to make the job easier. Thanks again.
