Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 11-16-2011, 10:12 PM
stevo2412 stevo2412 is offline
eclipse oil problems ~help~!
i recently bought a auto 2000 eclipse rs 2.4L 4 cylinder off someone and unfortunately it has had quite a few problems. first the check engine light cause of a bad o2 sensor(i replaced the check engine light is gone.) then my exhuast rusted in half (had to get it welded 200$)....now my oil light keeps coming on when i idle it useually drops around 500-700 and my oil light comes on but once i start driving it goes off i need some help cause im no mechanic and i have no idea what to do.
thanks
Old 11-18-2011, 12:17 AM
808drifter 808drifter is offline
Re: eclipse oil problems ~help~!
Try check your oil level maybe????????
The Following 2 Users Say Thank You to 808drifter For This Useful Post:
Blackcrow64 (11-18-2011), stevo2412 (11-18-2011)
Old 11-18-2011, 01:58 PM
Well, I'm not stupid. That is the first thing that I checked. I think that I've got it figured out. But thanks anyways.
Old 11-21-2011, 06:11 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
It's normal to have lower oil pressure at an idle, but the oil light coming on would be an indication of the oil pressure sending unit. Perhaps you could try replacing it first to see if your oil light woes continue or not. If it is a bad sending unit, perhaps your oil pressure readings are also off from what you are seeing now.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 11-25-2011, 01:46 AM
it was the oil pressure sending unit thankyou very much guys
96 Eclipse Rs Non-turbo Vacuum problem. donidavis Eclipse Problem Diagnosis 27 08-29-2010 09:07 PM
1995 3000GT Turbo manual transmission problem rene8603 3000GT/Stealth 8 10-08-2009 03:49 PM
Please Help, '99 AT Mitsu Eclipse won't shift into 3rd '99EclipseProblems Engine, Transmission and Drivetrain 6 09-13-2009 10:03 PM
95 eclipse gs blue smoke won't start hcruz32 Eclipse Problem Diagnosis 1 03-20-2009 09:36 PM
1996 Eclipse-Oil capacity blasterman Eclipse Problem Diagnosis 1 03-19-2005 10:21 AM
