Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-16-2011, 07:44 PM
97copcar 97copcar is offline
Oil pressure issue
I have a 97 z28 with a LT1.
Oil pressure is normal while driving but, when the engine warms up and is at idle it drops so low the car sometimes stumbles and the check gage light has come on a few times.
I have pulled the code and I have egr code, I have a new valve and solenoid and will put them on the first chance I get.
Were do I start troubleshooting the oil pressure issue?
Old 11-17-2011, 07:44 PM
Re: Oil pressure issue
Thank you Captain Obvious.
If you have something helpful to post, I am all ears otherwise don't waste my time with your nonsense. Also, try using a spell checker.....
I am on here to hear from someone that can help me increase my knowledge and point me in the right direction to start finding the issue.
Old 11-17-2011, 08:07 PM
Tech II Tech II is offline
Do you have an oil pressure gage or an idiot light?
If gage, what is pressure on startup? Does pressure drop linearly as temp rises? In other words, does it start out around 40-60psi, and then as the oil warms and thins out, does it gradually drop to zero or near zero?
Or does it drop abruptly without warning?
Or is pressure dropping because the engine is stumbling?
Have you verified oil pressure with an external pressure gage?
Also, have you been consistantly been using the same oil and filter?
How is oil condition? Does it smell like fuel?
Has the engine had any recent work done to it?
Old 11-18-2011, 06:57 AM
See answers in Red.
Originally Posted by Tech II View Post
Do you have an oil pressure gage or an idiot light? The gage in the dash cluster is reading near 40 at startup, then as the engine warms up it starts to drop. I have an idot light on, it is throwing a EGR code.
If gage, what is pressure on startup? Near 40 Does pressure drop linearly as temp rises? Yes In other words, does it start out around 40-60psi, and then as the oil warms and thins out, does it gradually drop to zero or near zero? It only makes it to near zero while at idle, i.e. at a read light.
Or does it drop abruptly without warning? no, drops gradualy.
Or is pressure dropping because the engine is stumbling? I am not sure, the pressure drops and when it approches the red line is when the engine starts to stumble.
Have you verified oil pressure with an external pressure gage? No, I don't have access to one.
Also, have you been consistantly been using the same oil and filter? Yes
How is oil condition? Does it smell like fuel? I have not checked it, I will check tonight when i get home.
Has the engine had any recent work done to it? Yes, new starter was put in and an oil leak at the valve cover was repaired. This issue was present before the work was done.
Old 11-19-2011, 02:27 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
I think your oil pressure is only dipping down that low because of the stumbling caused by the faulty egr. Take care of that first and see if it continues. If so, it could just be a bad sender/switch.
Old 11-19-2011, 05:00 PM
Thanks Genopsyde, i'll get those parts installed as soon as i can and report back.
Old 01-18-2012, 11:22 AM
Sorry it took so long, life has been fast and furious for me.
I replaced the egr valve on Monday and drove it Tuesday but, it still had the light on. When I got home yesterday, I cleared the code. The drive in this morning did not show any improvment. It still idles rough and the oil pressure drops after warming up. Do I need to give it a few days forthe pcm to realize the egr was replaced and adjust to it or do I need to start looking at something else?
Old 01-18-2012, 11:38 AM
Genopsyde's Avatar
The President
Exactly how low does the oil pressure drop? Does it only do this at idle? How does it act under acceleration? Any possibility of recording a video?
Old 01-18-2012, 12:03 PM
If left alone, the oil pressure will drop to the orange slash mark on the left of the gage, it has even turned on the check gage light on before.
It stumbles during acceleration in the 1,500 to 2,00 rpm band, outside of that acceleration is fine.
I can see if i can get a video, it may take a few days as I have to line up a passenger to do the taping.
Old 01-18-2012, 12:22 PM
Genopsyde's Avatar
The President
I think a compression check is in order.
Old 01-18-2012, 12:39 PM
Thanks, that testing is beyond my abilities. I'll make an appointment with my mechanic.
Old 01-19-2012, 12:21 PM
Genopsyde's Avatar
The President
well let's do all the troubleshooting that can be done without costing you money. I know space is tight, but let's see if you can do this.
while the car is running at idle, unplug the injector connectors one at a time and listen for a change in idle. If the idle does not change for the worse on any cylinder, then you have a misfire on that particular cylinder.
I only suggest the compression test to rule out internal engine failures.
Genopsyde's Avatar
The President
I'm thinking you may have an optispark issue fwiw.
Old 01-19-2012, 04:02 PM
j cAT j cAT is offline
my guess is the cat convertersor exhaust is plugged up. the egr is part of that back pressure issue..
opti issues are missfires at the higher rpm. I would still check that coolant is not getting into it from the weep hole.
the idle issues can be PCV or hoses to and part of the crankcase venting system.
the IAC in the throttle body needs periodic cleaning and the passage ways to insure a smooth correct idle.
96 impala ss LT1 .....
Old 01-20-2012, 08:53 AM
Thanks, I look at that stuff this weekend. That is stuff I feel confident I can check.
Oil pressure issue...Sludge, sensor or other? Steven14217 '97+ 5 04-29-2007 05:34 PM
91 park ave 115,500 miles oil pressure issues Opps123 Park Avenue 2 06-28-2005 08:29 PM
Oil Pressure Issue david-b Off-Topic 3 05-10-2005 09:08 AM
Low Oil Pressure issues Tonupboy Rodeo | Passport | MU 12 01-07-2005 07:46 PM
oil pressure issues 1991CamaroRS Camaro Discussions 18 02-18-2004 01:01 AM
