Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 11-16-2011, 09:16 AM
lyonkster lyonkster is offline
2000 Camry Door Squeak
I just bought a 2000 Camry, and both front doors have a loud squeak when opening or closing. I can't tell if it's coming from the hinges or the black rod that slides in and out of the door when it is opened.
I am planning to investigate it this weekend, but if someone knows the solution, that would save me the hassle . I noticed the same squeak on almost all the other Camries I test drove, so this seems like a common problem.
Thanks,
Leon
Old 11-16-2011, 09:41 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 2000 Camry Door Squeak
Yes, it is a common problem. They haven't changed the basic design for this part for over a decade...my '92 did it too. Your best bet is to spray the top and bottom sides of the rod with a lithium grease and work it into the door mechanism. If you get a can with a straw tip, use that to squirt some deep inside.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
The Following User Says Thank You to jdmccright For This Useful Post:
lyonkster (11-16-2011)
Old 11-16-2011, 09:45 AM
Hope this helps!
Thanks for the quick response! I suspected it was the rod, so I'll give it some grease and see if that fixes it. Thanks a bunch!
Old 11-17-2011, 08:39 AM
Jerry80871852 Jerry80871852 is offline
I recently bought a 2001 Camry, both of the front doors has a squeak in them. I found it to be the outer edge of the door not far from the rearview mirrors, rubs against the rubber door seal, gasket, as I open & close the doors.
Have a great day,
Jerry
1992 Chevy S-10 Blazer
4 X 4, 4.3 W engine 3.42 gears
172,000 & still going
Sold
2010 Toyota Tacoma Double Cab 4X4 V6
4.0 V6 DOHC 24V VVT-i 236HP Engine
12,000 plus miles
Bought 10-22-11-2001 Toyota Camry LE SuperWhite 4 Door sedan I-4 89,680 miles
Old 11-17-2011, 11:29 AM
I'll check for that too.. How did you fix the rubbing?
Leon
White 2000 Camry LE V6
Old 11-17-2011, 03:43 PM
There's no way to fix it outside of cutting off or bending the edge of the door & or trimming the door seal.
Have a great day,
Jerry
Sold
12,000 plus miles
Old 11-17-2011, 03:49 PM
Oh, so yours still squeaks? I wonder if spraying some silicone on the seal might help (temporarily at least)...
Leon
Old 11-17-2011, 06:43 PM
Probably, On this one it looks like its been doing this since it was new. I used white grease in the spray can on the door hinges trying to stop the squeak, yet I kept having a squeak. I kept opening & closing the door finally finding what the squeak was.
Have a great day,
Jerry
Sold
12,000 plus miles
The Following User Says Thank You to Jerry80871852 For This Useful Post:
lyonkster (11-18-2011)
Old 11-18-2011, 06:09 PM
Jerry, you were absolutely right, this is exactly the source of my squeak. I could easily see where the door corner rubs against the weatherstrip when the door is opened or closed. There is some wear on the weatherstrip, and on one side the door corner has the paint actually worn off . This is so unlike Toyota, I am surprised they screwed this one up.
I burnished some silicone spray onto the weatherstrip, and the noise is gone, for now. We'll see how long it stays quiet.
Thanks for the tip!
Leon
Old 11-19-2011, 10:58 AM
Your welcome. I suppose that was a fault on all Camry of this generation.
Have a great day,
Jerry
Sold
12,000 plus miles
2000 Toyota Camry Rebuilt Transmission Computer Problem gujuchokra Camry/Camry Hybrid/Vista 5 08-20-2009 08:45 PM
2000 Camry Drivers Door Handle nbaptist Camry/Camry Hybrid/Vista 0 02-28-2006 10:10 AM
2000 camry door locks not working darrenchild Camry/Camry Hybrid/Vista 1 12-29-2004 01:34 AM
2000 camry 3.0 xle vs 2000 1.8 gs htype_r Integra 1 10-23-2003 09:58 PM
squeaking clutch squeaks like an old door SiLviA[S14] 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 3 09-03-2003 09:50 PM
