Old 11-15-2011, 12:03 AM
jesus122473 jesus122473 is offline
Exclamation grand prix gt 2001 trany problems
can anyone help me to diagnostic what's the problem with my trany,
my transmission is shifthing a little bit hard!
and only start doing this after driving for awhile,and if i stop for a few minutes and restart driving again it shift's smooth again for a few miles and go back to shifthing hard.
can this be a sensor or vacumm,or is the sign of the tranny goine bad?
thanks in advance for your help,
p.s. there is no engine light on !
Old 11-15-2011, 10:09 AM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: grand prix gt 2001 trany problems
Hello!
Has the tranny been serviced recently? If not, you might want to replace the fluid and filter in it.
Another posible cause would be a dirty MAF sensor; the PCM relies on it and other sensors to provide better performance. Remove it with a Tamper proof torx bit (I can't recall the actual number) and use some MAF cleaner or, ir not available, electric contact cleaner both available at most autoparts stores.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 11-15-2011, 01:08 PM
Tech II Tech II is offline
There are some tranny codes that DON'T TURN ON THE CE LIGHT....
If a code sets, the PCM may command full line pressure, causing hard shifts.....
When you shut the car off, everything resets....probably shifts fine....then the code sets, and the PCM commands full line pressure again.....
Places like AutoZone will read codes for free....
Old 11-15-2011, 05:29 PM
olopezm's Avatar
Which could also be the case of the MAF, that's why I suggested to take a look and clean it first.
Autozone will read the codes, but the scanner they use will only read some BASIC transmission codes if they are set. The use of a fully capable scanner would be a better idea but I don't know how much would a shop charge. In other words, the fact that the autozone scanner doesn't shows any codes still doesn't means there are no codes at all...
Oscar.
Old 11-15-2011, 08:30 PM
"Autozone will read the codes, but the scanner they use will only read some BASIC transmission codes if they are set."
What the heck are you talking about? Read only "basic" codes? If a code is set, it will be read by the scan tool......
Old 11-15-2011, 10:22 PM
olopezm's Avatar
Of course but that doesn't means a low end scanner like most used at autoparts stores will read every single code, as well it won't perform the diagnostic tests a high end scanner can. Hence the need of a proper diagnostic.
The fact that the CEL is not on doesn't means there are no codes, just like you said; just like the fact that a scanner is not showing any codes doesn't means there are no problems...
If it makes you feel happier I'll say generic codes instead of basic codes.
Old 11-17-2011, 03:49 PM
I am not sending him to AutoZone for a diagnostic test, just to read codes....I'm sure their scanner is more than capable of reading gereric as well, as dealer specific, for example, like a P1811....
99 Grand Prix acceleration problems MConder Grand Prix 7 12-11-2010 10:08 PM
1990 Grand prix le problem Erik23512 Grand Prix 1 11-05-2010 12:14 PM
1997 grand prix anti-theft system components Konstantin Grand Prix 8 10-13-2010 10:20 AM
98 Grand Prix Wont Start, need help ASAP! atdudonis Grand Prix 3 06-17-2010 08:57 AM
2001 Grand Prix GT trany Problem roman1978 Grand Prix 3 12-23-2005 09:03 AM
