Old 11-14-2011, 11:07 AM
dmathusek dmathusek is offline
When cold fuel pump does not kick in
I have a 1999 Windstar. When it starts getting cold out the fuel pump sometimes does not kick in. When its warm out I have never had a problem. I put a new fuel pump in and the same thing happens. I have tried changing relays, fuses, and still does it. Any ideas?
Old 11-14-2011, 11:44 AM
Scrapper Scrapper is offline
AF Premium User
Re: When cold fuel pump does not kick in
you may have got a bad pump or your fuel relay? have you changed gas filter? when you turn key on can you hear the fuel pump loud or just a click? you may want to put some sea foam in it to clean injetors.
good luck.........
Old 11-14-2011, 01:53 PM
12Ounce 12Ounce is offline
You could actually measure the voltage going to the fuel pump. Which relays did you change? With new ones?
The "PCM power relay" and the "fuel pump relay" are the important ones.
91 hatch si fuel pump cover and hard line not connected? no fuel tank pressure? is that bad 94cordvtec '88 - '91 Civic | CRX | Wagon | Shuttlee 7 10-09-2010 05:26 PM
fuel pump turns, but not pumping MarPac Windstar 0 08-18-2008 03:07 PM
what kind of fuel pump does a 94 88 have? crc or cac J_EtoCoV Eighty Eight 2 04-22-2007 04:59 PM
My fuel pump does not like the cold. kenny-1907 Silverado 6 01-03-2005 04:15 PM
