Old 11-13-2011, 10:43 PM
Foxymom Foxymom is offline
04 Gr Prix Supercharger leak?
This is my ex-husbands car, I know very little about it but it has started smoking and had my Father look at it and the leak seems to come from the Supercharger, a pinkish color? He thinks it is dripping on something and that is what the smoke is from. I have read online that you need to have the oil changed in the supercharger (did NOT know that) and I know this one has NEVER been changed. Any ideas before I take it to get an estimate? It is a 2004 Pont Gr Prix GTP 3.8L Supercharged V-6. Here are the upgrades that were done on it before I got it:
BORLA CAT-BACK EXHAUST
RANDOM TECHNOLOGY HIGH FLOW CAT
K&N COLD AIR INTAKE SYSTEM
MSD BLASTER COILS, MSD BLASTER IGNITION WIRING, NGK SPARK PLUGS
MODIFIED RAM AIR SYSTEM
I wasn't sure how much information you needed. Thanks for any advice offered, my ex is military and does not live near me to work on the vehicle.
Old 11-14-2011, 10:44 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 04 Gr Prix Supercharger leak?
Welcome to AF!!
The supercharger oil should be changed periodically but I don't think that is your problem. It sounds more like you have a coolant leak. It could be from several different sources depending on where you see it dripping from. If you could post a picture of where the coolant is coming from that would give us a better idea of what is happening. If not there could be several issues. First, a leaking lower intake manifold gasket especially if you have water in the oil or smoke coming out of the tailpipe. Next it could be a bad water pump if the coolant is from the front of the engine. Another potential is a bad coolant elbow on the front of the engine.
If you take it to a repair shop, get an estimate for repair from more than one mechanic. Costs vary widely from shop to shop and you may get hit with a large cost for the repair. Good Luck!
The Following User Says Thank You to GTP Dad For This Useful Post:
Foxymom (11-14-2011)
Old 11-14-2011, 03:15 PM
Tech II Tech II is offline
Might be able to see the leak with a coolant pressure tester.....b ut you have to Isolate the leak.....all it has to do is land on the hot exhaust to smoke....
SC'ers usually leak at the nose cone/pulley area....usually more seepage than a leak.....Very easy to check fluid level....but this fluid is not pink.....there is a torx screw that you remove to check level....should be at the bottom of the threads....usually checked every 50K miles...
The Following User Says Thank You to Tech II For This Useful Post:
Old 11-14-2011, 07:45 PM
Okay, I uploaded a couple of images I just took, let me know if this helps and thank you for your help!
Old 11-14-2011, 08:21 PM
danielsatur danielsatur is offline
Check the little black plastic coolant elbows from the belt tensioner going to the Intake.
If bad, they can be bought in the Dorman section at your local auto parts store for around $2.00 / 1hr repair
Also do AF-> Pontiac->Grad Prix Thread tools search ''Coolant Elbows''
The Following User Says Thank You to danielsatur For This Useful Post:
Old 11-15-2011, 03:10 AM
CrazyHorst CrazyHorst is offline
I am guessing from the uploaded pictures this actually is the gasket under the supercharger....correct me if wrong but there is coolant going up thru the supercharger casting for the throttle body heat...could also be seals between the supercharger body and the throttle body itself also.
Perhaps if you clean and dry everything up, then start the car, you can diagnose where the weepage is coming from.
Another clue would be the level in the overflow bottle or the radiator neck (checked COLD!!) would be getting lower also.
1988 Chevy R-30 1 ton DRW pickup (217k)
1991 Chevy S-10 4WD pickup (192k)
2000 Grand Prix GTP (218k)
2002 GMC Yukon (185k)
2009 G8 - GT (46k)
The Following User Says Thank You to CrazyHorst For This Useful Post:
Foxymom (11-15-2011)
Old 11-15-2011, 04:14 AM
We have already checked the radiator while the fluid looks kind of the same, it thankfully looked fine. Thanks for your help, I may just end up calling someone to take a look at it, I should have sold the car last year!
My 97 2door grand prix is has four leaks and etc HELP Universalsoul Grand Prix 4 08-23-2011 04:59 PM
1998 grand prix GTP 3.8L V6 supercharged, random misfire gtpmaddi Grand Prix 2 04-19-2011 08:16 PM
2002 SE leaking coolant jamc204 Grand Prix 2 06-17-2010 08:56 AM
Fuel leak in the engine compartment wolfkin_j Grand Prix 3 12-11-2009 07:25 PM
GTP Anti-Freeze Leak bbaker1985 Grand Prix 2 04-03-2009 05:35 PM
Tags
'04 , grand , gtp , prix , supercharged
