Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 11-11-2011, 10:50 PM
springoflife springoflife is offline
Question Need Help with Rear Electronic Level Control, Please
I have a 2000 Chevy Venture. It has the rear air shocks and leveling system. It comes in handy when I tow my camper or a utility trailer. It has worked flawlessly for four years, but quit. It no longer engages the compressor. Ever!
I checked the fuses, and they are OK.
If I pull the connector that goes to the compressor relay, there are four wires; two small wires for the coil (controlled by the sensor), and two heavy wires for the contacts (which go to the compressor). The heavy wires have power. But the coil wires (from the sensor) never do. Placing a jumper from the heavy power wire over to the thin coil wire activates the relay and the compressor engages. So that confirms it in my mind that the Sensor (with integrated electronic control) never activates the relay.
I purchased ($$$) and installed a new Sensor, and much to my dismay, the system is still dead.
Any ideas?
Old 11-12-2011, 07:29 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Need Help with Rear Electronic Level Control, Please
Do you have the inflator option in the rear also? If so, does the compressor work with that?
Old 11-12-2011, 04:38 PM
Yes, that option is installed. However, in the four+ years I've owned the van, the rear inflator never worked. But the axle sensor/compressor/air shocks did, so I just never relied on the inflator. If I ever needed to inflate something (i.e., air mattress), I just used the cigarette lighter to power a separate, portable inflator. The fact that the built-in rear inflator is still dead doesn't really help us troubleshoot the system.
Old 11-12-2011, 05:13 PM
gmtech1's Avatar
The Following User Says Thank You to gmtech1 For This Useful Post:
springoflife (11-12-2011)
Old 11-12-2011, 05:14 PM
gmtech1's Avatar
Wow, that came out big, sorry.
Old 11-12-2011, 07:16 PM
Thumbs up Re: Need Help with Rear Electronic Level Control, Please
Correction, "Wow, that came awesome!"
THANK YOU! Let me digest that for a few days, and see what I come up with.
Need help with 99 jimmy powertrain control module deadbolttattoo Jimmy 1 03-18-2007 06:05 PM
93 525 - need help with up & low control arm Rupesy 5 Series 3 08-09-2006 08:22 PM
Need help with rear head cover removal problem for 91 SSE Ekoastn Bonneville 0 04-19-2004 12:43 AM
Need Help with WIRING : CRX controls SIvic '88 - '91 Civic | CRX | Wagon | Shuttlee 0 07-22-2003 02:20 AM
Need help with rear susp.(lil long) Carnivore '88 - '91 Civic | CRX | Wagon | Shuttlee 7 05-15-2003 12:02 PM
