Go Back   Automotive Forums Car Chat > Buick > Regal
Old 11-09-2011, 08:00 PM
geckowest's Avatar
geckowest geckowest is offline
a/c frost
Hi, I've been reading this forum for sometime now and it's been nothing but great help. I have an issue that is greatly puzzling me right now and could use some help on. I have a 2000 regal and ......when I use the heater should I have an abundant amount of condensation on the A/C pipes?
example...When I turn on the HEATER, the A/C compressor comes on (clutch clicks) and frost develops on all the A/C pipes and the heat isn’t all that hot through the vents and when I shut off the car, there’s a big puddle, (which I thought was a major water leak). So any help would be appreciated.
Old 11-10-2011, 12:49 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: a/c frost
If you use the defrost or bi level setting the AC will engage. This causes the condensation that you indicate. If the AC compressor comes on when you don't have the selector on these two settings you may have an issue with the switch but I doubt it. Also if you turn the heater setting up into the red you shouldn't get the condensation either.
One thing you may want to check is to see that the drain for the heater box is open so that you aren't drawing too much condensation through the coil and causing the issue.
Old 11-10-2011, 06:40 PM
brcidd's Avatar
brcidd brcidd is offline
Re: a/c frost
Frosty lines can be an indicator of loss of refrigerant in your a/c system. Frost occurs when suction pressure goes extremely low..
Suction pressure can go low with refrigerant lost through a leak.
Your variable stroke compressor does not cycle off with low pressure- it is a continuous run system.
How does the a/c cool when 80+ degf out? If poorly, then you need an a/c repair.
An a/c system recovery will tell you how much refrigerant is in the system.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Frost on inside of winshield? 5spdfrk '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 13 03-07-2004 07:29 PM
Clear/Frosted taillights for 88-91 civic 4dr? Posey88cvic4dr Exterior | bodykits | Lighting 1 10-03-2003 08:30 AM
frosted glass for car 1996Z28SS Cars in General 2 07-20-2003 03:11 AM
Tafetta vs. Frost White CraniumDesigns '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 11-20-2002 07:00 AM
