Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 11-09-2011, 06:40 PM
mrmiami123123 mrmiami123123 is offline
how to change belts 99 neon sohc with ac
anyone here has a good tip on changing both belts on 99 plymouth neon sohc thanks
Old 11-11-2011, 01:19 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: how to change belts 99 neon sohc with ac
Removing the upper radiator hose will help with the p/s belt. You will lose some coolant, but not too much if you plug the hose with a towel or something like that. Slightly loosen the 2 adjusting bolts and slide it down to put the new belt on.
As far as the alternator belt, I usually cut the old one off and then slide the new on and turn the crankshaft and slide the belt on while its rotating. Its not too bad, but can take a few tries. It's quicker than loosening all the nuts to adjust and so on.
2003 Dodge SRT-4
How to change timing belt? RainSpirit44 SVX 2 03-25-2009 05:30 AM
strange problem possibly with 96 neon sohc. Jim Ramstad 1st Gen 95-99 9 12-26-2007 04:09 PM
how to change belts on mirage 2000? fireflymkz76 Mirage 0 06-11-2006 12:23 PM
Changing belt - how often? jy.lv Maintenance 1 01-01-2006 06:37 PM
How to change belts?????Anyone? CanadianG Maintenance 13 04-01-2002 10:20 AM
