Go Back   Automotive Forums Car Chat > Buick > Regal
Old 11-08-2011, 06:28 PM
rnelson rnelson is offline
1996 with Crankshaft Sensor Fault Code
I have a 96 Regal 3100 and the fault code is returning a bad crank shaft position sensor for the sensor behind the harmonic blancer. Both sensors and the harmonic balancer have been replaced with the code checked between each item being changed out. I am still getting the same fault code.
When the engine is cold, it will not idle right. After the engine warms up a bit, things are fine. Please help.
Old 11-08-2011, 07:46 PM
Tech II Tech II is offline
Re: 1996 with Crankshift Sensor Fault Code
Did you replace BOTH crank sensors? Or just the one behind the harmonic balancer?
Old 11-08-2011, 08:25 PM
Yes both sencers have been replaced plus the harmonic blancer // the code reads sencer behind harmonic blancer
Old 11-10-2011, 08:51 PM
Originally Posted by rnelson View Post
yes both sencers have been replaced plus the harmonic blancer // the code reads sencer behind harmonic blancer
do u have to be a qualified mechanic to answer someones question /im what u call a shade tree mechanic but ive seen some questions i know because ive been down that road before myself thanks for this web sight
Old 11-11-2011, 07:45 PM
OK, what is the code?
Old 11-11-2011, 08:04 PM
I dont remember the number but it be same on all the dinostic machine that shows crankshaft position sencer bad the one behind the harmonic blancer // wont number or code be same
Old 01-20-2012, 07:20 PM
SuperFudd SuperFudd is offline
Consider the posibilty of a bad crimp on connection of a connector to wire at the "computer" end of the wire from the sensor, though in my experience that would cause the engine to quit / not start. Wiggle the wires at the plastic multiwire connector.
1997 Hyundai with O2 sensor 2 codes ChicBowdrie General Discussion 1 03-03-2011 05:18 PM
97 Escort Help with O2 Sensor OBD2 Code doug2060 Escort 3 07-23-2007 07:25 PM
Is O2 Sensor Fault Code 100% Correct? BETTER THAN A WRX Maintenance 12 06-10-2002 05:25 AM
