Go Back   Automotive Forums Car Chat > Hyundai > General Discussion
Old 03-03-2011, 02:18 PM
ChicBowdrie ChicBowdrie is offline
1997 Hyundai with O2 sensor 2 codes
I have a 1997 hyundai elantra with 138K miles. I bought it recently with P0136 and P0141 codes and other issues that need to be fixed before passing inspection. The front exhaust was leaking in the flex pipe area. I installed a connector as a temporary repair until I can determine whether inspection is worth it. The exhaust sounds OK, but I'm not sure it is 100% sealed. Do the codes mean anything if there is any exhaust leaking?
After "repairing" the exhaust leak, I waited for warm weather to address the O2 sensor code issues. Some 2K miles later, the P0136 code (O2 sensor 2 ciruit malfunction) was replaced by P0137 (O2 sensor 2 circuit low volts). Another 2K miles later, I now have only a P0138 code (O2 sensor 2 circuit high volts) and the P0141 code which has always been there. Assuming these O2 sensor 2 codes are meaningful with a possible exhaust leak, is there anything to do before replacing the O2 sensor 2 and/or exhaust pipe? I don't want to spend $500 to repair a $750 car that still might not pass inspection because the cat converter is shot.
Old 03-03-2011, 05:18 PM
danielsatur danielsatur is offline
Re: 1997 Hyundai with O2 sensor 2 codes
1) Have the exhaust leaks fixed and welded at a local muffler shop.
2) Check the fuse for your H20 sensors.
If the catalytic converter is shot isn't it throwing a DTC?
Beyond frustration with sensor codes Ninety7PrixGT '01-'05 Civic 3 06-01-2010 12:33 PM
1997 K1500 O2 sensor code P0141, which one?? snydes Silverado 2 10-30-2007 05:31 PM
Help with Throttle Position Sensor Code Nayr747 Off-Topic 2 05-28-2005 07:26 PM
1997 hyundai accent body kits logfloggen42 Accent | Verna 0 02-15-2005 09:51 AM
1997 Hyundai Elantra Axle Seal wesley7777 Elantra | Avante 2 03-07-2004 09:07 AM
Tags
p0136 , p0137 , p0138 , p0141
