Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-04-2011, 04:07 PM
gallacmic's Avatar
gallacmic gallacmic is offline
Contradictory Blow off Valve
I have a vent to atmosphere style blow off valve with the two barbs on it. The 1st barb is on the top portion of the blow off valve and the 2nd plums underneath the diaphragm. The 1st barb on top has a hose that recieves both boost and vacuum as it is plumbed to the intake manifold. The 2nd barb is plumed to the pipe that the blow off valve is mounted to so it only receives boost pressure. The problem I am having is the screw is adjusted all the way out to try and get rid of the compressor surge which is evident by the loud psh psh psh psh sound I get when I shift instead of the one loud smooth PPSSSSSSSSHHHH! But the stupid thing is with it adjusted all the way out it is getting compressor surge but it wont let me get full boost (9psi). If I tighten the blow off valve screw I can get my full 9 pounds and it always surges. If I loosen it it surges and I lose boost. WTF!?!?!?!?!?!?
If its adjusted softer to where I'm losing boost pressure why in the world am I still getting compressor surge???
Old 11-04-2011, 06:30 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Re: Contradictory Blow off Valve
First off what kind of car do you have? 2nd what blow off valve are you running?
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 11-04-2011, 08:02 PM
gallacmic's Avatar
Its a 98 2g Eclipse with a 420a turbo.
Here is a link of the exact same blow off valve
http://www.ebay.com/itm/UNIVERSAL-AD...item2eb8e1be72
Old 11-06-2011, 10:27 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Cap the lower barb. All you need it one vac/boost port on the BOV. Get rid of the second lower hose, and cap it off. The top connection will see (as you stated) both vac and boost, which will open or close the BOV. With the lower one connected, it's pushing the diagram open while the top is trying to do the opposite.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-06-2011, 02:48 PM
gallacmic's Avatar
Ok I will definitely try that but that makes no sense why they would make a blow off valve that fights itself like that. To my understanding the lower and upper barbs deliver in my case 9 psi above and below the diaphragm which is an equal amount of pressure therefor cancelling each other out as far as moving the valve open or shut. The spring on the other hand is in the upper portion holding the valve shut and when the throttle plate slams shut it now has 18 psi vac pressure in the top portion and 9 psi boost in the lower barb and 9 psi boost below the valve itself in the inter-cooler piping. The idea is that should make the valve open rather quickly. But with how shit goes on this it might actually do the trick to cap off that damn hose.
Old 11-07-2011, 08:29 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Yes you are correct, the lower barb is suppose to be hooked up to boost only and is suppose to equalize pressure in the BOV. So the BOV only seals with spring pressure which makes for a quicker release. Most of us do not run the BOV setup like this, however i have never seen an issues come from using this setup. Also another things is that this is an ebay knock off BOV. I am actually using an ebay BOV and it works fine, had to replace the diaphram in it but doesn't leak. Like Dave said remove the lower line and cap it on the intercooler pipe, dont cap the port on the BOV.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-07-2011, 12:11 PM
gallacmic's Avatar
K I will try that for sure. One thing I think might be a problem too is that the blow off valve shares the same "T" as my FMU. Not sure if that would be a problem since the air only pushes on the diaphragm in the fmu and the air does not actually leek out or anything. But perhaps I need to drill a hole and tap it so the BOV has an isolated vacuum/boost reference. What do you think?
Old 11-07-2011, 01:12 PM
david-b's Avatar
Dave is THAT guy
Shouldn't matter. Manifold pressure is manifold pressure. Ideally you want each item using vac to have it's own reference line and use basically no tees, however here it doesn't matter.
75 Monte Carlo
Old 11-07-2011, 02:55 PM
gallacmic's Avatar
Ok today I received my little air filter in the mail I'm going to use on the BOV just to make sure during idle it does not suck air in un-filtered. I also decided to do a boost leak test again just for kicks and found out that the 60mm throttle body has a major leek on the shaft where the tension spring is. Would a boost leek cause the BOV to not operate correctly? I know that under load and right when I shift my vacuum gauge reads 21-22 of vacuum that normally would go straight to the BOV to open that son bitch. I pressurized the intake to 10 psi doing the boost leek and the throttle body was hissing pretty loud so during 21psi vacuum would be twice as bad I think. Perhaps this is the culprit for my annoying BOV problems!! A STUPID O RING!!!!!
Old 11-08-2011, 08:06 AM
Holset powered 420a
Vac is no measured in psi, its 21 inches Hg. That shouldn't be causing the BOV issues you are having. If the leak was bad enough it would cause a high idle.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Blow off valve, or diverter valve? Chirpn'3rd GTI 3 09-04-2005 07:36 PM
HKS: Blow off valve wanted RBpower Classifieds 0 01-14-2002 07:49 AM
FS: Intercooler w/ Blow-off valve and Piping kraznik Classifieds 0 01-09-2002 03:52 PM
Cheap Blow Off Valves MENIOS Performance 0 11-11-2001 11:14 PM
