Old 11-04-2011, 09:55 AM
buffercat buffercat is offline
No heated seat
I have no heat on the drivers side only. There is a black box under the seat approx 3"x3" that clicks when the switch is pushed. Is it the pad itself, what wires am i looking at for high low etc. Oh 2002 Lesabre Limited, if i don't get this fixed I'll have a wife with a hot head and a cold butt
Old 11-04-2011, 02:22 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: No heated seat
Probably need a heater element, unplug the element and measuer resistance across it. It should be around 3.0 ohms. You probably have one for the seat back also, the plugs are the same so make sure you check the correct one. It's a pretty common failure.
Old 11-04-2011, 04:19 PM
Tech II Tech II is offline
Re: No heated seat
GMtech1 is right......the elements go on these.......the elements are wired in series, so if one goes, you lose both(usually one is placed in the seat bottom, and the other in the seat back).......when you order them, you get both elements......some cars are "fun" to replace.....you have to remove the seat covers.....some covers are held in place with velcro, those are the easy ones......some are held in place with metal rings,,,,,those are the tough ones......the elements themselves are easy to install.....it's those seat covers that are the problem....
But you need a schematic to verify this.....there are two harness connectors going to the box and you have to know which circuits to test for an open circuit.....you do not want to replace those elements and then find out there was nothing wrong with them.....that it was that module under the seat, that was the problem....so check the resistance of the elements first...If "OL", that's the problem....
Old 11-05-2011, 02:49 PM
sooperduty's Avatar
sooperduty sooperduty is offline
Re: No heated seat
Probably the lower element has a burnt wire as it was on my regal. Check for continuity and then proceed to remove the seat cover and follow the wires. It was easy to see the burn. Solder the wires and you'll have heat again. I removed the seat for the repair. Going on the second winter for me.
2000 GMC SIERRA 2500 6.0
Heated Seats - adding to 98 Camry Chapol Camry/Camry Hybrid/Vista 2 12-02-2010 08:36 AM
Heated seats and rear heat / 2004 Z71 bsweasel Tahoe 11 01-22-2009 02:26 AM
Heated Seats/No heat richamer1 Montana/Montana SV6 2 10-28-2008 09:28 AM
02 Envoy no pwr seats or seat heat rmt entry kevin64 Envoy 0 10-31-2007 07:02 PM
heated seat not heating brewitzer Aurora 8 01-03-2005 06:59 PM
