Old 11-02-2011, 09:42 AM
robbyaube robbyaube is offline
Battery charge issue
Hi,
This question is for my dad regarding his truck. He has a 2000 Silverado 1500 and has been having charging issues. He says that when he goes to start in the morning voltage guage shows approx 14 V but then as he is driving along it kreeps up to like 17V as if it's charging the battery for no reason since it was already at like 14V. Is this indicating any issues? I guess he's wondering why the system is charging the battery with a 17V load when it's already at like 14V in the first place...
Thanks for any info on this.
Robby
Old 11-02-2011, 04:13 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Battery charge issue
Originally Posted by robbyaube View Post
Hi,
Robby
Dash gauge does not give a very good reading on charging volts.
Always put a volt meter on battery for propervoltage test.
Charging voltage should read around 14.4 -14.5
Engine off battery voltage should be 13.2
MT
Old 11-03-2011, 01:02 PM
j cAT j cAT is offline
Hi,
Robby
I have the same vehicle what is going on here is the alternator regulator is defective GM part. alternators now use the fiwed alternator regulator that is made to operate in an outdoor evironment. these corrode as GM built them. I purchased a new alternator of the improved design ..I suggest that you have this replaced soon to avoid damage sudden vehicle breakdown.
before replacing have battery load tested. have battery fully charged. removal of alternator is easy just remove battery ground first ...then bring to the auto store for bench test. this will confirm whats up !
Charing Issues. Battery Discharging. bueiz Tahoe 6 09-15-2010 09:55 AM
81 Volvo not holding charge SausageMike General Discussion 0 03-23-2010 02:23 AM
99 Jeep Grand Cherokee battery change issue. brutass Grand Cherokee | Grand Cherokee SRT8 3 01-27-2010 09:21 PM
96 Starting/Battery/Charging Issue VetteRacer Sable 0 09-07-2005 07:26 PM
Battery/Charging Issue TheGooch Explorer | Explorer Sport Trac 3 04-10-2005 08:32 PM
