Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 10-30-2011, 01:20 PM
vando002 vando002 is offline
'02 LS Driver Side Hub Assembly
2002 LS V8 - 70k miles
I'm in the process of replacing a bunch of front end parts due to bad boots and looseness and brake pads. I spun the rotor with the brake caliper and pads off and noticed a clicking noise in the hub assembly. I tried the other side, and no clicking. Is this the sign of a failed hub?
Thanks,
Old 10-30-2011, 09:01 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: '02 LS Driver Side Hub Assembly
Did you check to make sure it wasn't rubbing on the water shield and that there wasn't a piece of grass or something rubbing on the inner stub? Assuming there's nothing foreign rubbing on the rotor or stub, it could be a failed wheel bearing or possibly a problem with the ABS sensor or tone ring.
-Rod
Old 11-04-2011, 07:03 PM
-Rod
Nothing foreign rubbing. As I spin the rotor faster, the clicking gets faster. If the hub comes off easily, I'll change it. If not, I'll move on. Thanks for the reply!
Old 11-04-2011, 09:52 PM
shorod's Avatar
SHO No Mo
If they use salt on the roads in Wisconsin like they do here in Iowa, the hub assembly probably will not come apart easily. If it does, then it's not a bad job to replace the hub/bearing assembly.
-Rod
Old 11-06-2011, 11:21 PM
-Rod
I just went ahead and changed the hub assembly. Took only a few minutes to get it apart. I was fortunate to have recently purchased this car from someone who just moved up to IL from Florida. I've never worked on a car without rust, it's such a beautiful thing!!
Thanks for your help.
Old 11-07-2011, 06:31 AM
shorod's Avatar
SHO No Mo
Glad it worked out for you. Did the new hub solve the noise concern? It may be worth the effort to pull the other hub and put some anti-seize around the hub/bearing housing and on the mounting bolts so when/if it fails it won't be seized in place.
-Rod
Old 11-10-2011, 07:29 PM
There is no more ticking when spinning the hub. Good idea on the other side, if I ever take the other side apart for any reason, I will do that. Right now I'm dealing with trying to remove the drivers side valve cover to do the gasket job as I have a lot of oil in the spark plug tubes causing coils to fail. The passenger side was easy, driver side...not so much.
Thanks,
How to install mirror into LH side mirror assembly? Bill Deville Grand Marquis 2 10-12-2010 10:19 PM
driver side mirror assembly barbied 626/Capella/Capella Wagon 0 06-24-2005 11:46 AM
Front Driver side Hub (spindle) replacement RoraStar96 Aurora 4 07-24-2004 11:24 PM
P10 G20 Drivers Side Turn Signal Assembly A380Driver Classifieds 3 02-26-2002 02:31 AM
