Go Back   Automotive Forums Car Chat > Buick > Regal
Old 10-26-2011, 08:49 AM
capnrus789's Avatar
capnrus789 capnrus789 is offline
'99 Regal Turn Signal Connector
I had the fast blink issue, and not amber light for the daytime running lights, so I replaced the bulb. It worked, so I put the bulb back into the headlight lens assembly and back onto the car. Then it didn't work again. I took the lens out again, and remove dthe amber light from the lens. this time while looking at the connectory, one of the 3 wires pulled right out of the back. No connection, no light, right? Is this a crimped connection, or somthing that soudl be soldered back together? Is replacing the connector a better option?
'99 Regal LS 3800 Series II
'06 Subaru Outback Wagon
Old 10-26-2011, 09:36 AM
Tech II Tech II is offline
Re: '99 Regal Turn Signal Connector
Usually crimped with a seal....You can remove the connector from the plastic harness(usually a paper clip will depress the plastic node that holds it in place) and bring it to any GM dealership for replacement....just add a little wire so it won't pull on the connection....can transfer the old seal or get a new one with the new connector...
They have a crimping tool for this.....
'99 Venture-Turn signal Problems, ABS light. ART A Venture 6 10-24-2009 11:00 AM
1989 Buick Regal Turn Signal Failure Kid9630 Regal 2 02-10-2007 08:47 PM
98 Regal - Turn Signal problem, likely wiring Homebrew Hops Regal 8 03-23-2006 01:15 PM
1994 Buick Regal turn signals not working mamasocks Regal 1 12-30-2005 06:24 PM
97 Regal Turn Signal/Running Light Problem gonetobama13 Regal 3 07-09-2004 11:49 AM
