Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 10-23-2011, 06:46 AM
teamjp4 teamjp4 is offline
fitting/ valve "service use only"
There is a small valve that says for service only that comes from the radiator to the water pump. 3 radiator hoses attached to it. I broke that small fitting and jury rigged it with suction connectors to work. I do want to replace this. WTH is this? I could post a pic but if anyone knows, please help. The fitting broke inside the hose so now it's flushed with a hole in it. I stuck a suction fitting in there and sealed it but it looks tacky. I want to replace this.
Old 10-23-2011, 08:18 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: fitting/ valve "service use only"
I think you may be referring to the Water Crossover Assembly which contains the engine air bleed valve. I've pasted in an image from the service manual. Does this look right? If not, I would suggest you attach a photo of the valve in question by uploading it to a photo sharing service and pasting the link here.
-Rod
Old 10-23-2011, 01:34 PM
Here are the pictures, thank you for your help!
http://s182.photobucket.com/albums/x...=1319394684810
http://s182.photobucket.com/albums/x...3Dphoto4-1.jpg
http://s182.photobucket.com/albums/x...%3Dphoto-1.jpg
Old 10-23-2011, 02:00 PM
joegr joegr is offline
Looks like the engine air bleed on the gen I V6.
Honda Fit or Kia Soul! Michelle.cobb Car Buying Q&A 8 05-29-2012 02:13 AM
Intake coolant fitting biggflintmi C/K 6 04-15-2011 05:45 PM
(eBook) Buying New and Used Car Tips schumi_reloaded Car Buying Q&A 2 06-05-2009 11:18 AM
