Go Back   Automotive Forums Car Chat > Pontiac > GTO > Classic GTO's (1964-1974)
Old 10-22-2011, 11:43 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
1967 GTO Project!!!
Buying a 67 GTO to restore....
Wondering if a pontiac 455 would fit and bolt onto stock mounts and trans.
Are parts for a 455 hard to come by? I'm having a hell of a time finding a block in any condition....
What other models did the 455 come in?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 10-22-2011, 04:10 PM
maxwedge maxwedge is offline
A990 racer
Re: 1967 GTO Project!!!
455's were in poenty of Trans Ams and full size Pontiacs from about 71-76 in different states of tune. I believe it will come close to being a bolt in, I am sure there is some more specific online info.
Old 11-02-2011, 01:17 PM
MrPbody MrPbody is offline
AF -Advisor
Been gone for a while, health issues...
Yes, a 455 will "bolt right in". 455 blocks have both provisions for mounting ("early" and "late").
Using a 400 block and a "stroker" kit is MUCh more effective, and tougher. The block is the "weak link", not the crank. The 400 has smaller main journals, leaving more material in the bulkheads.
Get Jim Hand's book "How to Build Max-performance Pontiac V8s" and learn about the ol' Injun... It's the most current study of the Pontiac. We've made great "strides" since then, too. Not hard at all to get 600 HP on 93 octane. About the same "money" as a BBC at the same "level". Maybe a little cheaper...
What are your power goals? Purpose of the car?
Jim
Old 11-05-2011, 08:36 PM
A990 racer
Glad to see you back , Jim, hope all is good healthwise. BTW my fellow car club member has a aluminum bellhousing he claims is for 65 Pontiacs, 2 starter mounting positions, what say you?
Old 11-08-2011, 01:32 PM
AF -Advisor
The dual-starter bellhousing was used on Buick, Olds and Pontiac. The Olds and Pontiac are on the driver's side, Buick on the passenger's.
Jim
Old 06-09-2013, 08:31 PM
GTOHunter GTOHunter is offline
Send a message via Yahoo to GTOHunter
The 455 was first introduced in 1970 and ran for several years with lowering HP and compression after a few years,there can be a date casting if late 1969 on the Block and it's still consider or came out in a 1970 model Car,the Big Full Size Pontiacs also came out with the 455 engines also and the early engines are more sought after and desirable.
You can even take most older Pontiac heads from around 1968 and up for high compression or use later heads for lower compression and run lower octane pump gas!
1967 Gto Awood14 Classic Cars 3 06-10-2013 09:08 AM
Wanted 1967 GTO Convertible or 67 Chevelle SS 454 Convertible tblake Cars/Parts for Sale/Exchange 0 01-29-2011 08:31 PM
MPC '70 GTO project tonioseven WIP - Street 29 08-08-2005 03:38 PM
1967 GTO parts for sale JohnJ47 Classic GTO's (1964-1974) 0 03-01-2004 10:59 AM
1967 Gto vapors Classic GTO's (1964-1974) 0 11-05-2003 04:08 PM
