Old 10-21-2011, 02:38 PM
khairy1974 khairy1974 is offline
Help in airbrushing....
Hi all....
I have this little problem.....
I encountered rough surface after airbrushing my merc dtm2000 warsteiner with gloss black from zero paint.
How can I rectify this problem and what should i do? Btw, I am using Tamiya's HG Trigger airbrush....
Old 10-21-2011, 02:57 PM
Tibi Keke's Avatar
Tibi Keke Tibi Keke is offline
Re: Help in airbrushing....
Wet sand the painted arias with a fine sandpaper, 2000 is best. Pressure is probablly to high, pressure down and come closer to the model.
Succes!
Tibi
Old 10-21-2011, 11:26 PM
MidMazar's Avatar
MidMazar MidMazar is offline
Succes!
Also make sure the paint is thinned correctly although this would be your last thing that could be wrong since zero paints are usually thinned properly. But do the following as mentioned by Tibi.
In Progress
Old 10-22-2011, 04:21 AM
stevenoble's Avatar
Do all the things already suggested and also strain the paint before you use it. Sometimes you can get some small particles in the paint even though it is new paint, so I always strain it now before use. Also use a tack rag on the surface before you spray to remove any dust particles that may remain after the sanding process.
Steve Noble
I need help!! Cade.Garrett Car Buying Q&A 1 06-04-2009 07:07 PM
jdm h22 help sanchezjarodsdad JDM Motor & Parts info/chat 4 04-09-2009 05:14 PM
97 ram 1500 sport 4x4 tranny problems HELP ME! tabes Ram Pickup | Ram SRT10 3 03-14-2009 08:56 AM
3.4L 1996 Cutlass Supreme Help please!!! Zca62783 Cutlass Series 0 02-14-2009 03:27 PM
Help!! Airbrush not working anymore!! :((( D.J. Car Modeling 11 09-26-2003 09:08 AM
