Old 10-19-2011, 05:42 PM
95astroman 95astroman is offline
95 Astrovan Differential gear ratio
What's the easiest and least expensive way to change my 95 Astrovan (4.3L eng with auto trans) rear end gear ratio from the stock 373 over to a 273 gear ratio to help get better freeway gas mileage. I had a full size chevy van with 273 gears and loved it.
Old 10-23-2011, 08:54 AM
Blue Bowtie's Avatar
Registered Offender
Re: 95 Astrovan Differential gear ratio
The easiest method is probably installing a complete axle. You may not be able to find an axle with 2.73s, however. That may also be the least expensive, considering the cost of a new carrier, ring and pinion, bearings, shims, crush sleeve, and the cost to have it properly set up for side clearance, pinion depth, and preload.
Changing gear ratio options in MKII rear differential RatLabGuy General 0 09-17-2010 12:36 PM
Differential gear ratio LMP Engine and Transmission 1 08-20-2007 04:11 PM
rear differential gear ratio zeroskater Nova 5 10-26-2005 12:40 AM
differential gear for ratio 373 powel 3 Series 0 09-23-2004 06:21 PM
Transmissions,Differentials, Gear Ratios.... ARMYGUY556 What do you want to know? 0 08-08-2004 08:54 AM
Tags
1995 , astrovan , differential , gear , ratio
