Old 10-19-2011, 04:41 PM
sailor86's Avatar
sailor86 sailor86 is offline
O2 sensor
I have an 02 Mitsubishi Galant. For the past few months I have been driving around with the check engine light on. I went to the local Autozone and they told me my OBD port didn't work.. But when it came time to get inspected, the OBD came up with a bad Oxygen sensor. I promptly changed out the upstream sensor and the light went away. Then, a couple of weeks later, it came on again and once again it was the sensor that was diagnosed as faulty.
Now my question is: how common is it for an O2 sensor to go bad that quickly, what would be the cause, or could I simply have a sporadic problem with my OBD port?
If it ain't broke, see how you can complicate it.
2002 Mitsubishi Galant ES 4 cyl Front-wheel-drive. Automatic.
Old 10-19-2011, 05:43 PM
vgames33 vgames33 is offline
Re: O2 sensor
Sometimes a loose/worn pin in the DLC can cause issues with scanner communication, but it shouldn't set a light or anything.
Do you have the code number by chance? Depending on the code, you could have many issues causing a faulty O2 signal other than the sensor itself.
2000-2004 Avalon O2 Sensor Replacement Guide RexG Avalon/Pronard 0 06-23-2011 03:15 PM
o2 sensor danielgast46 F Series 0 03-15-2009 09:39 PM
Replacing Evap. canister Control Valve, Boost Sensor, and Knock Sensor? raja Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 16 06-04-2007 03:25 AM
