Old 10-19-2011, 01:58 PM
bambam2120 bambam2120 is offline
Transmission issues Help Please!!
can anyone tell me on my 1995 chevy s10 4.3, was driving it and was in 5th gear....we then shifted out to start slowing down and it stayed in gear. The shifter itself comes out of gear however when i release the clutch it still wants to take off. is this a clutch or pressure plate issue or is the trans just screwed? It will shift into any gear when i press the clutch in but still wants to take off in the gear its stuck in. any help is appreciated! Thanks
Old 10-19-2011, 04:00 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Transmission issues Help Please!!
Remove shift lever and check and see if the plastic button has come off the end of it.
If so replace it.
While you have the shift stick top off see if youcan take a big screwdriver and shift it with it.
You should have 3 slots in the shift rods.
First line the up with each other and it should be in neutral.
Then move one at a time to see if it is shfting in all gears.
Post back what you find and how it goes how it goes.
MT
ABS or Transmission Issue? Help Needed! gordon_gjs Impala | Impala SS 12 12-23-2009 07:39 PM
01 Explorer Sport Trac, Several Issues...HELP levi.calhoun Explorer | Explorer Sport Trac 7 03-29-2009 08:50 AM
96 Savana Transmission issues! **HELP** dblsix General Discussion 5 08-10-2005 10:51 AM
Sidkick rear light issue, help please dragan_sidekick_98 Sidekick 5 07-02-2004 03:52 PM
HP issues... Help please. -Dark-One- Tiburon | Tuscani 6 11-05-2003 05:17 PM
