Old 10-17-2011, 08:17 PM
Qazp Qazp is offline
Transmission
Anybody know any tunning shop where 2010 Honda Odyssey would be converted to manual transmission?
Old 10-19-2011, 01:12 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Transmission
Putting a manual trans into one is probably not a big deal, the problem would be cutting in the holes and pivot points for the shifter and clutch where none were available in the stock vehicle. You need a pretty good fabricator if you wanted a system that would last. You wouldn't want it half-assed together so it falls apart in a year....
Finding an ECM that could work with the stock engine and a manual trans could be problematic too, unless that engine is offered with a manual trans in another model....then you could possibly use that ECM. I'm basing all this on the assumption your vehicle was never offered in a manual, I'm not sure about that, I've just never seen one that I recall. You may have more luck on your model-specific forum any way, might try there.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Mustang Transmission part 2001 lawg8r Mustang Problem Diagnosis 1 04-13-2009 04:24 PM
Changing Transmission mkcody88 Accord/TSX/Accord Hybrid 2 04-05-2009 01:50 PM
h22 sh transmission used as a regular transmission h22 Prelude 1 07-31-2004 11:32 AM
?Transmission Fluid Needed for Manual Transmission? 85BlueGTI Golf 1 05-31-2004 08:21 PM
1988 Z24 Transmission problem, torque converter wont lock after transmission change Dale24 Cavalier 4 01-23-2004 02:29 PM
