Old 05-31-2003, 07:31 PM
Cychalen's Avatar
Cychalen Cychalen is offline
Koenig Specials Porsche 928 S4
I started this kit since I am still waiting for the the Hartge H5-24 body to dry.
I can't stop doing models. It's so addicting.
I hate mold lines and the body had a lot. The mold lines on the tires was a pain.
It took a while to paint the chassis since the front part of the exhaust is not a separate piece.
Interior will be in German grey, dark sea grey and the seats in white.
The body is going to be painted in gold.
Old 05-31-2003, 11:26 PM
chaos's Avatar
chaos chaos is offline
AF Premium User
Chasis looks real clean. A few gold jobs hitting the board of late!!
Old 06-01-2003, 09:37 AM
Cychalen's Avatar
Finished the interior and decided to see how it will fit the body.
To my surprise, the passenger side's fitting was poor to say the least, but driver side was fine. I thought that I was the one to blame and measured the the height for both sides and they are the same.
Is this typical for a Fujimi kit?
How do you solve this type of problem?
To add to my frustration, there were gaps that needed to be filled with putty too.
Old 06-01-2003, 10:36 AM
bigfrit's Avatar
bigfrit bigfrit is offline
??? strange thing you 've got there...
Maybe you could either cut a part out of the door or just lower the right peg where teh interior tub sits on teh chassis and then re-measure it !
Nice thing is you 've noticed these impureties at this moment, so you got the time to remake it!
Olivier
Old 06-04-2003, 05:39 AM
Cychalen's Avatar
Can someone tell me what happened here?
I put the can in hot water and then shake it really well like always, but this is what I got.
I used Tamiya TS-21 Gold.
Another angle.
Completed.
Datsun 240Z #5 Monte Carlo Rally 1972
Working on.
Nissan Primera
Old 06-04-2003, 05:51 AM
Jonno's Avatar
Jonno Jonno is offline
Send a message via MSN to Jonno
Is the area smooth?, if it is, Maybe there was too much thinner in that area
The model kit seems to be coming along nicely!
-Holden Berlina Turbo, RB30ET.
-Mitsubishi Legnum VR4
Old 06-04-2003, 05:57 AM
ZoomZoomMX-5's Avatar
Another angle.
Looks like the area was sprayed too wet/heavy at one time and the metallic particles separated. Let it dry, and then carefully mist on a couple more coats for it to even out. Your clearcoat is what needs to be ultra-smooth, the gold (being a base coat) can have some slight texture to it, to even out the metallic particles.
My Fotki Album
Old 06-04-2003, 06:18 AM
Cychalen's Avatar
Jonno, the trouble area looks smooth. The paint is still wet so I don't want to touch it.
ZoomZoomMX-5, I think you are right about the metallic particles. It looks dark at some angles and shiny at others.
Another question.
I kept spraying on the same area trying to cover it with another coat of paint. In the end I think I got 6 coats on it. As a result some details are gone. What do you guys/gals do to fix this and get the details back? I know sanding it will probalby work, but what about getting back panel lines?
Completed.
Working on.
Nissan Primera
Old 06-04-2003, 06:40 AM
Another question.
Yep, too much paint at one time. Fills in panel lines, makes metallic particles separate.
You can try to use a sharp-pointed scribing tool (Squadron makes a good one) to rescribe the panel lines, but it can be risky if the paint chips off, and the paint needs to be very dry. If you can get a set of curved riffler files, the triangular-section file works well in conjunction w/a pointed scribing tool. You might want to try that on a couple areas, or you might have to strip off the paint if it chips. Polly S easy lift off remover, or automotive brake fluid work on Tamiya sprays. I like to rescribe lines when the model is in the primer stage, primer and plastic are easier to scribe than gloss paint.
My Fotki Album
Old 06-22-2003, 04:23 AM
Cychalen's Avatar
I let the paint job dry for 2 weeks, sanded and applied a few really light coats of gold and clear as suggested. Thanks!
Here it is waiting for polishing.
Completed.
Working on.
Nissan Primera
Old 06-22-2003, 04:56 AM
tazdev's Avatar
tazdev tazdev is offline
I'm still here
looking much better.
Nice save
Old 06-22-2003, 05:06 AM
srlxy srlxy is offline
Looking GREAT!
Old 06-22-2003, 07:15 AM
Rtuned's Avatar
Rtuned Rtuned is offline
Wow! nice gold you got there. I need shade after you polish your Porsche.
Rtuned
Old 06-22-2003, 07:44 AM
TAKI's Avatar
TAKI TAKI is offline
Send a message via MSN to TAKI
love that gold!
looking good
Old 06-22-2003, 08:57 AM
gtr206 gtr206 is offline
Great choice of color for the body and A+ for the paint salvage dude!
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
