Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series > N-Body Problem Diagnosis
Old 10-16-2011, 01:35 PM
charlie40 charlie40 is offline
i have a 90 cutless that idles rough and when put under load will not respond. sounds like it is starving. i have replaced fuel pump, plugs, wires,fuel press reg. when i turn on key i have fuel press for a aminute then it drops off. when i start the car it stays about 35 to 40 lbs. also replaced icm. any thoughts about what is next.?
Old 10-16-2011, 07:30 PM
Tech II Tech II is offline
Re: 1990 3.3
See if it runs better with the MAF sensor disconnected....
Have you checked coil output with a spark tester?
Replace fuel filter?
Check for codes?
Old 10-23-2011, 10:03 AM
Re: 1990 3.3
got it replaced fuel rail and injectors runs great. thanks for looking
1990 lumina3.1 Euro starts cold, runs ok until stop engine, then wont restart bigtimmy45 Lumina 1 06-19-2010 11:39 AM
1990 Buick Century 3.3 Won't Idle bell345 Century 8 04-12-2005 06:34 PM
1990 3.3 rough running until wamed up wrenchead90 Caravan | Voyager 7 01-20-2004 08:42 AM
1990 3.3 rough running until wamed up wrenchead90 Caravan | Voyager 0 11-10-2003 11:04 PM
1990 3.3 Won't start... Xodus921 Caravan | Voyager 1 10-28-2003 07:37 PM
