Old 11-10-2003, 10:29 PM
wrenchead90 wrenchead90 is offline
1990 3.3 rough running until wamed up
does anyone have any idea what would cause my 3.3 to run rough until it warms up.it backfires and acts like it wants to die.i have changed the coils,coolant temperature sensor,map sensor,tps sensor,and have checked fuel pump pressure,replaced fuel filter.i have also changed plugs and wires,but it still runs rough.any help would be greatly appreciated.
Old 11-13-2003, 02:32 PM
yale329 yale329 is offline
Re: 1990 3.3 rough running until wamed up
Hey freind, let me know if you find a solution.
Old 12-06-2003, 09:29 PM
fubufolks fubufolks is offline
I had the exact same problem with a Pontiac Phoenix until my neighbor (a mechanic) told me what was wrong. It was the automatic choke pull- off. It took me $50 and 5 minutes to fix it myself. Good luck.
Old 12-11-2003, 05:05 AM
bridget36907's Avatar
bridget36907 bridget36907 is offline
does a caravan have a choke pull?
2005 Grand Prix GT
3800
1995 Chevy Caprice
LT1 5.7
1986 Dodge Ram
Old 12-11-2003, 12:14 PM
It's actually called a choke pull-off. I believe every vehicle with an automatic choke must have an automatic choke pull-off. Best way is to call a discount auto parts store and ask them, "How much for an automatic choke pull-off for my vehicle?" If there isn't one, they'll tell you.
Old 12-12-2003, 01:14 AM
tazman tazman is offline
While replacing the choke pull-off you may want to clean the throttle body. Disconnect the large hose coming from your air filter chamber and spray a throttle body cleaning solution into it. Follow the instructions listed on the side of the can or bottle before starting.
Old 12-16-2003, 09:06 AM
RABarrett RABarrett is offline
All of these people are referring to the days when a vehicle had a carburetor. In fuel injection, all fuel delivery is controlled electronically, not with user replaceable parts. I would try scanning the vehicle for codes. My suspicion is that either the vehicle is not warming up fast enough, or some sensor is confusing the computer into thinking the same thing. If no codes are set, it will be necessary to check each sensor for correct readings. It sounds to me like the mixture is too rich up until the time that the computer reads the O2 sensor (closed loop.) The O2 sensor, when it reads a rich mixture will tell the computer so and will lean it out accordingly. Until the engine warms up enough, the computer is basing the fuel delivery on air flow, coolant temp, throttle position sensor readings and a software package. If one of these is off, the result will be incorrect fuel delivery. I have not examined the vehicle; I am guessing, but this is an educated guess. Ray
Old 01-20-2004, 08:42 AM
dodgerunner dodgerunner is offline
Send a message via AIM to dodgerunner Send a message via Yahoo to dodgerunner
Check to see if you have an idle air motor. If it is dirty and sticking might be your problem.
