Old 10-13-2011, 12:28 AM
tompkinzz tompkinzz is offline
2000 windstar 3.8L stalling when hot. Help me Please!
I have a 2000 ford windstar SEL 3.8l that is stalling after it warms up. It always turns over at first and runs great until the engine warms up. It then idles down until it stalls. It will not start back up unless I give it gas. It recently was doing this and I did a Intake Manifold & Valve Cover Repair putting these parts in'
Updated front valve cover
8 New intake isolator bolts with new seals
Upper intake manifold gasket set
Idle speed control motor gasket
Fuel pressure regulator vacuum line
Throttle body gasket
PCV Vacuum line
and replaced MAF, cleaned IAC.
After I did this the Van ran for a week and then started doing the same thing. I noticed that if I take the PCV Vacuum line off the intake it idles high but stays running. I noticed that my coolant level has slightly gone down and I suspect that there may be a leak but Im unsure at this point. Ive tried adjusting my throttle without success, and no MIL comes on, no codes present. I want to bring it to a shop but have had trouble finding a honest mechanic in my area. I would like any ideas of what can cause stalling like this, so Im more prepared and can have an educated guess as to what may be the issue. I really dont want to be taken to the cleaners by a dishonest or uneducated repair guy. Thanks
Old 10-13-2011, 04:48 AM
12Ounce 12Ounce is offline
Re: 2000 windstar 3.8L stalling when hot. Help me Please!
Just as a test, loosen the coolant cap a round. Then let us know if this affects the engine's performance.
Air bag code 44, Windstar 96, 3.8l kafkacell Windstar 0 09-07-2010 07:56 AM
2000 SEL 3.8l Battery Cable Hot !! Nox Windstar 2 06-12-2010 12:06 AM
93 Regal Custom 3.8L stalling when hot Regalblues Regal 1 09-26-2009 02:23 AM
3.4L 1996 Cutlass Supreme Help please!!! Zca62783 Cutlass Series 0 02-14-2009 03:27 PM
2000 Windstar 3.8L Air Cond Mackab Windstar 1 06-24-2005 12:49 PM
Tags
stalls , warm , windstar
