Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 10-11-2011, 07:47 PM
essikr essikr is offline
Fuel tank
I replaced the fuel tank on my 91 SSE and now the SES light comes on after you drive for 10 minutes. When you park for a time and restart the car the light is off .It comes back on again after 10 minutes. When replacing the tank I did find part of the EVAP line from the tank to the canaster rusted thru and replaced it.The gas cap appears to be OK. The engine runs fine no problems starting or accelerating . Where should I look?
Old 10-11-2011, 09:50 PM
Tech II Tech II is offline
Re: Fuel tank
This is not an OBD II vehicle, so you are not going to see evap codes.....ground "A" to"B" in the ALDL connector, turn key to "on", and count the flash codes, to find out what code is turning the SEE light on.......
The Following User Says Thank You to Tech II For This Useful Post:
essikr (10-12-2011)
Old 10-12-2011, 12:16 PM
Red face Re: Fuel tank
Thanks for the info ,the codes had nothing to do with the fuel tank. Got two codes 13 and 14. I beleive they are for O2 sensor and coolant temp. It might be the temp sensor as the engine did not get hot. Checking it out today.Thanks again for pointing to the right direction.
Old 10-14-2011, 04:30 PM
Question Re: Fuel tank
So,if you have codes 13 & 14 can both of these be a problem. I think I can test the O2 sensor,the code says open? Is there more than one sensor on my car?
The car doesn't get hot so the temp sensor may be bad . Can one or the other cause both codes to come up? Hope I'm not being a pain!
Old 10-14-2011, 10:22 PM
Re: Fuel tank
You are correct, in what each code represents.....
check the wiring to the O2 sensor, and also to the temp sensor....
Not sure if they share a common circuit(power/ground), where both would be affected...
Was the light on BEFORE the tank was replaced?
Old 10-15-2011, 08:17 AM
Re: Fuel tank
No,it came on after. The light come on after driving 10 min. .It does go out when you park the car .
how to replace a gas tank chrisl757 FYI - How to... 3 12-29-2009 08:34 AM
2000 Metro Fuel Tank Issue. Unbelievable!! dkvarda Metro 1 07-30-2009 05:34 PM
whine from fuel pump in fuel tank? sinfull90 Silverado 2 10-09-2004 11:23 AM
how do i take a tank off to change fuel tank dakotadad Dakota 2 02-07-2004 03:51 PM
Fuel tank fuel pump HHHhhhhmmmmm........ Mach.9 Nissan Cima | Nissan President | Infiniti Q45 1 12-08-2003 12:40 PM
