Old 10-11-2011, 06:32 PM
astrovankyle astrovankyle is offline
Possible fuel pump problem
I have a 2000 Astro passenger. When attempting to start the vehicle, starter just turns over seems to not be getting fuel. A couple shots of starter into the intake gets it started. When driving down the road and giving it the gas to say pass a car, seems to choke up/stall. If I just give it a slow increasing pedal, it will get up to say 60 mph, possibly more. Was told to have catalytic checked. Had hole cut in first unit and it exhausted fine. So not an exhaust pressure issue. Was then told by mechanic that I need a new fuel pump unit. Big price on that one. In researching, I find there are rebuild kits, even down to a pump intake sock to the pump.
Question: Think it is the pump? Do I need the whole pump unit? Just possible blockage from a dirty intake sock, or even if it is get the whole unit with everything for 49.00 shipped and put a whole new unit in and be done with it. Thanks all that answer this problem for me.
Old 10-11-2011, 06:40 PM
brcidd's Avatar
brcidd brcidd is offline
Re: Possible fule pump problem
Astro vans were built for 20 years- would be good to know which one you have-- probably a high pressure system--multi-port etc...I use my "pump in a bucket" to prove/disprove your issue.
What is your EOKO (engine off key on) fuel pressure? probably not enough.
Don't put a piece of junk in your tank-- use only new quality parts.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 10-12-2011, 12:15 PM
drew300 drew300 is offline
My '97 had a weak pump. If it started, it ran fine. I was told it needed a MINIMUM of 60 psi to start. I had 59. I replaced the pump with an aftermarket one. It's still fine after 5yrs or so.
(GM wanted $875.00 for one in a box)
You should check your fuel filter. (it's pretty cheap) If you know electrics, i measured the current draw of the old original pump at the fuel pump relay, in the fuse box. My old one was about 5 amp draw, not enough. The replacement is 10 amps. Also, the connector at the pump is know to burn from the high amperage. That can cause a problem too. If you can, drive it until the tank is low. It's pretty heavy to drop it.
Starter/fuel pump problem xum Caravan | Voyager 1 10-08-2011 10:57 PM
1991 Regal Custom- Possible Fuel Pump Problem snickerkisses Regal 1 02-10-2010 10:08 PM
93 suburban fuel pump problem. robert1984 Suburban 2 12-15-2009 02:21 PM
Fuel pump problem lmattiso Rodeo | Passport | MU 0 04-25-2009 02:08 PM
99 ES 300 Possible Fuel Pump Problem Malloy ES300/ES330/Windom 1 10-02-2004 06:48 PM
