Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-10-2011, 09:10 AM
gorent gorent is offline
Question Horn keeps blowing fuse!
I have a 94 cutlass supreme s that blows the horn fuse every time I try to honk it! I replaced horn with new delco unit and it worked fine for two weeks and started blowing fuses all over again! It will even blow fuse if horn is not plugged in! I have swapped relay with fog lamp one which is the same and traced wires for short in harness under hood as far as possible, but cannot find a wiring schematic in Chilton or Haynes manuals that cover horn at all! Any suggestions would be very much appreciated at this point! Car is starting to have constant gremlin issues like this!
Old 10-10-2011, 11:33 AM
maxwedge maxwedge is offline
A990 racer
Re: Horn keeps blowing fuse!
I would try running a new wire from the relay to the horns and temporarily eliminate that part of the harness, nothing else on that circuit?
Old 10-23-2011, 12:25 PM
Ran a new wire from relay to horn and grounded horn to mounting stud an now all works fine! THANK YOU!!!!!!!!!!!!!!
Old 10-23-2011, 03:46 PM
A990 racer
Thumbs up Re: Horn keeps blowing fuse!
You are welcome, thanks for the post back.
PLZ help 94 grand am ignition fuse keeps blowin! thewizard67 Grand AM 7 05-03-2014 07:46 AM
95 Jeep Grand Cherokee Radio Fuse Keeps Blowing - Dead Battery ajcool Grand Cherokee | Grand Cherokee SRT8 1 04-25-2010 10:30 PM
Help! 2000 Z71, Power Locks keep blowing fuse VonDutch78 C/K 5 01-16-2004 06:47 AM
hazard lights keep blowing fuses afcro Lumina 0 10-26-2003 10:08 PM
Dash lights keep blowing fuses crx_insanity '88 - '91 Civic | CRX | Wagon | Shuttlee 3 10-22-2003 05:31 PM
