Old 10-09-2011, 11:40 AM
Radiatorkid Radiatorkid is offline
Power Door Lock
I've got a 2000 Windstar with a Drivers Power Door lock which is not Working. I replaced the actuator with a new universal one which I checked out before installing. It appears that I'm not getting any power from the switch to the actuator. All other locks are working fine. Only the Drivers Side Front door is not working. All fuses appear to be good also. Any ideas on what to check next? Thanks.
Old 10-10-2011, 07:38 AM
phil-l phil-l is offline
Re: Power Door Lock
The driver's power door lock actuator also recently failed on my '00.
I replaced it with an OEM-style unit - and it now works fine. Personally, I don't bother with the "universal" kits, and your experience isn't the first time I'd heard of problems.
You mentioned testing the actuator. Did you test it while attached to the van's wiring harness? Do you have a voltmeter to verify that no voltage is reaching the actuator connector?
Are you sure all of the wiring harness connectors in the door are properly mated?
Sorry, I don't have many ideas beyond this...
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
Old 10-10-2011, 07:22 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: Power Door Lock
Hi have the same problem, it looks like the actuator is weak or something; whenever I try to unlock the doors I can see it trying try to move.
I inspected and cleaned the actuator to no avail; I was willing to install a new aftermarket actuator but read many negative comments. I decided to leave like that because I wasn't willing to spend more money on an OEM one (had bigger things to worry about).
Later I found some guy who had the same problem and turned out to be the Front Electronics Module located under the dashboard. In case you replace the actuator and still doesn't works the FEM would be the next place to look.
Phil-l, I wonder how did yours stop working? Plain dead or or was weak like mine?.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 10-10-2011, 08:01 PM
Re: Power Door Lock
Success!! After more reading of the owners manual, I missed a fuse under the hood in the Power Distribution Box. Fuse #14 is for the FRONT Drivers door only. It was Blown. New Fuse and Everything is working right. Wife is very Happy! Now I'm wonder why the old fuse Blew. Maybe the OEM actuataor was pulling to much current in it's old age? Thanks again for your input.
Old 10-10-2011, 08:59 PM
Re: Power Door Lock
Oscar.
Oscar -
Mine was weak. At first, pressing the unlock button twice was enough to get it to work. Then it got progressively worse.
I took the old one apart after replacing it. There's a small motor that drives a gear mechanism inside of the actuator. I suspect the motor brushes were wearing badly. It's been fine since I replaced it (about 6 or so months ago).
What does the FEM look like - and exactly where is it? What did a replacement cost?
1995 Contour GL 2.5
The Following User Says Thank You to phil-l For This Useful Post:
olopezm (10-14-2011)
Old 10-13-2011, 05:06 AM
northern piper's Avatar
northern piper northern piper is offline
Re: Power Door Lock
I've replaced 2 on my 2000 now, both replacement models ( a dorman part) not the "universal" one and not a Ford OEM one. In both cases when I opened up the unit one of the teeth of the small geared wheel had broken off. I'd suspect the window lock jamming or sticking leading to the motor spinning wearing the tooth. I too wouldn't fiddle with a "universal" model as the dorman is readily available and fits well.
2000 windstar 3.8
2010 honda pilot touring
Muskoka Canada
The Following User Says Thank You to northern piper For This Useful Post:
Old 10-13-2011, 08:00 PM
olopezm's Avatar
Re: Power Door Lock
Thanks Phil,
That's pretty much the same mine does. I guess I will replace it when possible. It doesn't really bothers me having to use the key to open the door.
The FEM is under the dash near the drivers feet and should look like a black box (I think) I'll post a pic of the exact location tomorrow.
Piper what's the part number of the dorman replacement, is it available from autozone?
Oscar.
Old 10-13-2011, 08:08 PM
Re: Power Door Lock
Here's a link to Autozone's lock actuator for the Windstar, Duralast #DLA136:
http://www.autozone.com/autozone/par...37024_36114_0_
rockauto.com carries the Dorman part, 746148
1995 Contour GL 2.5
Old 10-13-2011, 08:30 PM
Re: Power Door Lock
I"m pretty sure this is it. I just did a really quick search on the dorman site.
http://www.dormanproducts.com/p-3032...ator%2520Motor
2000 windstar 3.8
Muskoka Canada
Old 10-14-2011, 06:57 AM
Re: Power Door Lock
piper -
Hmmm - The pics at the link don't look like my replacement... Wait: And the site says it's for a *right-rear* application.
I think this is it:
http://www.dormanproducts.com/p-2732...ator%2520Motor
1995 Contour GL 2.5
Old 10-14-2011, 07:11 AM
Re: Power Door Lock
yessir Phil.... you're right.. that is the one.
that dorman site is pretty good. I use it now for when I'm looking for parts a lot..
2000 windstar 3.8
Muskoka Canada
Old 10-14-2011, 11:31 AM
olopezm's Avatar
Re: Power Door Lock
Thanks guys,
I'll check those part numbers at the store.
Oscar.
Manual door lock wont stay unlocked! 95 Toyota Camry DerekDougherty10 Camry/Camry Hybrid/Vista 1 05-16-2011 05:13 PM
2002 Buick Regal remote control door lock receiver brytheisen Regal 2 07-20-2010 11:07 AM
Power door locks keep re-locking (intermittent) sbarmann Explorer | Explorer Sport Trac 7 09-19-2006 10:34 PM
94 door power door locks drivers door only fischfly2 Bonneville 0 01-22-2006 05:08 PM
Power Door Lock will not unlock when pressing the door lock clark35 Bonneville 0 06-14-2005 01:08 PM
