Hi All
![]() Got a 95 Toyota Tercel as my run around car and all of a sudden the drivers door won't open. Handle works on outside, inside handle works, lock manually and with key works, but the door is stuck shut! Took as much of the door panel off as I could with door shut, and can see that the levers and arms move when I use the lock, handles etc...any ideas besides a tall cliff?! Got a lot of miles left in this ole clunker!
Re: 95 Toyota door stuck shut!
Then lock itself is probably bad, with the release handle/s in the unlock position give it a "shoulder block".
| The Following User Says Thank You to maxwedge For This Useful Post: | ||
whyohwhy (10-08-2011)
I had to deal with a stuck door on my Camry earlier this year due to a broken spring inside the lock mechanism. If the lock mechanism used is similar (they are both similar model years) you might be able to use my solution here:
http://www.automotiveforums.com/vbul...d.php?t=441937 Hope this helps!
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
| The Following User Says Thank You to jdmccright For This Useful Post: | ||
whyohwhy (10-15-2011)
Thanks all
Have tried absolutely everything...pushing, shoving, kicking, cussing, with handles pulled open and lock unlocked..all seems to be in order but won't open. Threw in the towel and am having a body shop look at it first of this week! Txs for the tips, links and will keep you posted in case I have some new light on the situation lol
