Old 10-07-2011, 03:33 PM
mopar man's Avatar
mopar man mopar man is offline
96 taurus master cylinder
I have a 96 taurus gl just replaced the master cylinder went to bleed the brakes and its not building up any pressure any ideas what the hell is going on
I stepped on a Cornflake, and now I am a cereal killer.
Old 10-07-2011, 10:03 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 96 taurus master cylinder
Did you bench bleed the master cylinder before installing it? If not, it may take A LOT of pumping to get it to build pressure in the lines. Have you also checked for leaks in the system that would prevent it from building pressure? Why did you replace the master cylinder, was it for the same issue by chance? And do you just mean building pressure to bleed the brakes, or do you mean it seems like there is no power assist?
-Rod
Old 10-14-2011, 02:59 AM
mopar man's Avatar
sorry shorod about the late post I had to replace the master cause the system had a huge pressure spike and blew out it and the two rear wheel cylinders its building pressure now
1996 Taurus master cylinder smellywetdog Taurus | Taurus Wagon 6 12-28-2009 03:51 PM
2002 Taurus brakes? Master cylinder? AC repair? gunther98 Taurus | Taurus Wagon 4 09-25-2009 02:05 PM
slave cylinder or master cylinder wrenchboss26 Cherokee 3 05-20-2007 12:45 AM
Master cylinder - slave cylinder part sizzen56 Wrangler 1 12-23-2004 08:42 AM
