Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 10-07-2011, 09:59 AM
drichers drichers is offline
PCM B 20 amp fuse blew (only once) 98 Tahoe
Last week the fuse blew. I replaced it and it has been fine since. I measured the current through that fuse and it was never over 10 amps. I have a long trip planned pulling my camper and I'm a bit worried it will happen on the highway. I have read the threads on this. Any ideas?
girl from Memphis
Old 10-07-2011, 10:10 AM
joel macneill joel macneill is offline
Re: PCM B 20 amp fuse blew (only once) 98 Tahoe
Is there any metal parts near the pcm that were not factory? maybe a metal seam for a body structure point? It sounds like the fuse is blowing due to an intermittent short and those are the worst to diagnose. Did the fuse blow during startup, taking a corner, full throttle? If you narrow down this to a possible clue then maybe you can track other things like harnesses rubbing on suspension, or firewall, or possibly the engine itself. The computer fuse is likely blowing from one of these because if it were a shorted sensor for example, then the computer would enter a failsafe mode and just not work with no data communication. The good thing is that the computer is relatively easy to access.
The Following User Says Thank You to joel macneill For This Useful Post:
drichers (10-07-2011)
Old 10-07-2011, 10:33 AM
nothing new installed recently except the starter and rechecked the wiring to that yesterday. It blew when i was slowing down at a stop sign.
Old 10-07-2011, 11:05 AM
777stickman 777stickman is offline
This fuse powers 2 things.
1. Constant 12v to the VCM.
2. Power to the fuel pump thru the pump relay.
So, I would suggest that the wiring from the pump relay to the fuel pump be examined very closely. The pump power wire is grey. The connector at the pump has been known to cause issues.
Best of luck.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
The Following User Says Thank You to 777stickman For This Useful Post:
WIn 95 "S" PCM 30 amp fuse blow famzapata Windstar 1 07-17-2011 08:26 PM
Wire melted once, fuse blew wierd months after. ice745 Car Audio 7 04-14-2007 08:13 AM
A horn fuse blew out, and I dont know which one it is... yourdeathwish S-10 1 11-19-2005 06:39 PM
